Does Run Fast 351 Eventually!
Has thanked: 171 times
Been thanked: 158 times
Post by b.c.flat hat » Sun Jun 23, 2019 5:45 pm
Another busy day in the man-cave, fitted the final front suspension bits, shimmed the calipers, fitted the pads, shockers and springs and finished the chassis brake pipes. Did the final steering rack assembly and rough adjusted the toe-in. Raised and roped the chassis to the beams, took out the wooden beams and put a set of Wolfrace on.
Warning. If you use Spax dampers, fit them with the adjuster knobs AWAY from the trunnions, otherwise the steering lock-stops will forcibly remove them! Yep, had to take it apart, turn the dampers round and refit!😳
Has thanked: 155 times
Been thanked: 1052 times
Post by scimjim » Sun Jun 23, 2019 6:47 pm
Looking good Brian :D
Much easier to adjust the dampers in situ with the adjuster knob inboard too.
Has thanked: 428 times
Been thanked: 370 times
Post by CNHSS1 » Sun Jun 23, 2019 7:03 pm
Good progress Brian, we will soon have to change your moniker from 'Crusty' to 'Shiny' Crouch :lol:
Post by b.c.flat hat » Mon Aug 26, 2019 5:50 pm
Thanks to visits to Craig's man cave for a few "garage nights" and Sunday afternoon at Curbs I'm back in the garage after these terrible past weeks and have found my mojo again somewhat.
The seized top ball joint on the off-side front suspension has been changed then the clutch and gearbox have been fitted to the block. Fiddly alignment jobs take so much longer without another's helping hands.
Has thanked: 295 times
Been thanked: 229 times
Post by Corky » Mon Aug 26, 2019 5:59 pm
It’s been nice to see you out at Loton and Curbs BC. I’m sure the garage work will be great therapy. Keep at it. :wink:
Post by CNHSS1 » Mon Aug 26, 2019 6:01 pm
Nice one Brian 8)
Has thanked: 194 times
Been thanked: 104 times
Post by efi_sprintgte » Mon Aug 26, 2019 7:21 pm
Keep it up BC
Been thanked: 106 times
Post by swoakes » Mon Aug 26, 2019 9:20 pm
Nice work BC 8)
Post by b.c.flat hat » Tue Aug 27, 2019 6:17 pm
Got the engine/gearbox back in the chassis but missing the spacer under the g/box mount, the old one was plywood so I'll make a new one.
Been thanked: 164 times
Post by gtcse8 » Tue Aug 27, 2019 6:37 pm
Brian I have spare Steel spacers, Both sizes for the Auto`s and Manual.
Never actually measured them but probably 5/8" or 7/8", no where near them till mid morning on Wed.
Might help you having to bore out the Large centre hole for the mounting bolt ?.
EX SST 1800Ti
Has thanked: 327 times
Been thanked: 157 times
Post by MikeyBikey » Sat Aug 31, 2019 9:17 pm
Brian, epic work. Want to do mine next :D
Post by b.c.flat hat » Tue Sep 03, 2019 3:54 pm
It's been a week of admin and jousting with bureaucracy but managed a good couple of days in the garage. I tentatively took the packing out from under the g/box mount, spied the alignment and it seems right. The prop shaft was fitted through the hole in the chassis and bolted up, it seems to sit correctly in the lower third of the hole. The chassis will droop when the body weight is on it, taking the hole down a bit and putting the shaft somewhere in the middle.
Took the opportunity of a few dry days to do a mahoosive shunt to change the temporary chassis under the body. I need repairs done where the front suspension towers give support so cut them down and had the outriggers off on the old frame then used the wheel-free beams on the lift and the engine crane to swop chassis. Just got a few bits to fit to the overhauled frame then it's a mammoth sanding job on the body.
Post by b.c.flat hat » Wed Sep 11, 2019 10:28 pm
Refitted the strut between the suspension towers and the anti-roll bar then started sanding. I rigged a rope to keep the vacuum hose clear.
Been thanked: 129 times
Post by BigBobPilot » Wed Sep 11, 2019 10:54 pm
That's a hell of a vacuum hose!
SS1 CA18DET race car
Benc
Has thanked: 94 times
Been thanked: 52 times
Post by Benc » Thu Sep 12, 2019 9:43 am
Hi Brian
Just admiring your sander and hose :w
I need to do a bit of body work on the gold racer and need to buy an electric sander is your sander just orbital or is it random orbital?
Any recommendations?
