Manny's 78 GTE
manny
Has thanked: 37 times
Been thanked: 22 times
Re: Manny's 78 GTE
Post by manny » Sun Apr 23, 2017 9:03 pm
Good day all
Today's mission was to sort out the mixture and tappet clearances- twas a lovely day for it! after a couple of hours or so - i finally i have a sweet sounding V6 and it now idles at 850 rpm..planting your foot down (idle) shows no black plumes of richness- managed to get 19 In:Hg of steady vacuum at idle.
I then took it for blast down the M6 - windows down - kickdown - it does sound very nice!!..i was a bit naughty on the slip M6\M5 but my mate was impressed by its turn of speed!
Got home and could not open the door from the inside :roll: which was on my last MOT failure...
Ta
Manny
manny
Re: Manny's 78 GTE
Post by manny » Tue Jun 06, 2017 7:46 am
Good day all,
today was take the GTE to work day - i can report the idle is now at a steady 800 ish rpm - and did note the vacuum gauge did not always swing to the 'bad economy' sector - as before even coughing near the throttle pedal would make it jump!
SO very happy the new the carb\spacer and tappet adjustment appear to have been positive - just thought i would share.
Ta
Manny
Been thanked: 559 times
Re: Manny's 78 GTE
Post by Roger Pennington » Tue Jun 06, 2017 8:36 pm
Well done! it makes all the work worthwhile :D
AnotherTim
Re: Manny's 78 GTE
Post by AnotherTim » Wed Jun 07, 2017 8:16 pm
Just found this thread so I'm posting in it so that it gets listed in my "View your posts" list. That's how I navigate this place, which is why I tend to miss most of what's going on.
:D
I love your body/engine hoist. Reminds me of a medieval trebuchet-like contraption. I expected the text underneath to say
manny wrote:initially will be used to lift the body at the front ...then fling it across the field and over the castle wall
manny
Re: Manny's 78 GTE
Post by manny » Wed Jun 07, 2017 8:35 pm
AnotherTim wrote:Just found this thread so I'm posting in it so that it gets listed in my "View your posts" list. That's how I navigate this place, which is why I tend to miss most of what's going on.
:D
funny you should mention trebuchet-- was exactly what i had in mind as i hacked it together :D...but thank you sir
StevieF
ROE425M
Post by StevieF » Wed Jun 07, 2017 10:28 pm
Hi Manny
Just wondering if you ever managed to find anything out about Dad's old car?
Stevie
manny
Re: ROE425M
Post by manny » Thu Jun 08, 2017 4:58 pm
StevieF wrote:Hi Manny
Stevie
I did speak to my my MOT father (last week Tuesday)- but he has not been in contact with the owner so far - i am popping in tomorrow to drop off my SS1 for a MOT - so will remind him - having said that someone did pm me regarding the car - as i think they were looking at purchasing it...
Will update as soon as i can
Ta
Manny
StevieF
Re: Manny's 78 GTE
Post by StevieF » Thu Jun 08, 2017 10:47 pm
Thanks very much for the update!
manny
Re: Manny's 78 GTE
Post by manny » Sat Jun 17, 2017 10:09 am
Good day all,
I have a spare 6DA wiper delay unit - i was in a box of spares from the SS1 ..it has the connectors etc..can it be easily fitted into the existing wiper wiring in the GTE?
Ta
Manny
Has thanked: 154 times
Been thanked: 1051 times
Re: Manny's 78 GTE
Post by scimjim » Sat Jun 17, 2017 10:12 am
There may be some work needed - apparently the connectors are reversed on the 6 series.
http://www.scimitarweb.co.uk/sgwrs/view ... 32&t=27380
manny
Re: Manny's 78 GTE
Post by manny » Sat Jun 17, 2017 10:19 am
Mr King..
i am such a Doofus...as i was looking at the Wiki article this morning...
I thank you saaar
Manny
manny
Manny's 78 GTE
Post by manny » Thu Nov 23, 2017 9:31 am
Good day all,
car is in for its MOT...fingers crossed...and stiff drink in hand :cry:
Ta
Manny
Been thanked: 69 times
Manny's 78 GTE
Post by Old and Slow » Thu Nov 23, 2017 12:55 pm
My eyes are crossed for you! :shock:
Hope it all goes well.
manny
Manny's 78 GTE
Post by manny » Thu Nov 30, 2017 4:11 pm
Good day all,
well it failed :
Nearside Rear Upper Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Rear Upper Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Front Upper Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Nearside Front Upper Front suspension ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
Nearside Headlamp insecure Dipped Beam (1.7.3)
Offside Headlamp insecure Dipped Beam (1.7.3)
Advisory notice item(s)
Nearside Front wheel bearing has slight play (2.5.A.3c)
Offside Front wheel bearing has slight play (2.5.A.3c)
Offside Rear Shock absorber has slight corrosion to the casing (2.7.2a)
so i have asked the garage to attend to the items and make it roadworthy once more...not too disappointed to be honest. I had a good run since bought.
Once it has a new MOT - i will probably sell, as my TR is near completion and the GTC , Ti need TLC...
Ta
Manny
Has thanked: 50 times
Been thanked: 258 times
Manny's 78 GTE
Post by AJL Electronics » Thu Nov 30, 2017 4:19 pm
That "Front wheel bearings have slight play" is one of my irritations. It should be noted that if there were NOT slight play, then they are too tight. Your modern spotty MOT yoof with his laptop, doesn't understand taper roller bearings. I sometimes have had to take in the factory workshop manual before they will understand and remove the advisory. Looks like you need to educate them!
Not sure what your chassis state is from that fail, I would want another opinion I think.
