Manny's 78 GTE
manny
Has thanked: 37 times
Been thanked: 22 times
Re: Manny's 78 GTE
Post by manny » Sun Mar 19, 2017 9:14 am
Good day all,
well i fitted the new carb (mid Jan) but nothing else from the Christmas list- but no matter what i tried could not start the car!!!...so carried out the the usual diagnostics:
1.Checked for fuel flow - primed via electric pump- all OK when i operated the throttle
2.Checked the Lumenition for spark generation - all OK when the optical sensor was interrupted
3. Attached a spare lead and plug to the no 1 distributor cap- all good when cranking- a nice fat blue spark
4. As well as i could checked the pipes for any possible air leak sources or blocked them off
so i was lost to think what to do next...
5. reset the carb settings as specified by AJL's PDF - no change
it was only when i accidentally elbowed the distributor - i noted it was loose- ie i was able to turn it ( slight resistance) :(
so with the wife at wheel ( her words as she sat in the driver seat " i forgot how S**T looking this car was" ..... :D nice)- i asked her to crank it continually as i twisted the distributor - and eventually it burst in to life but it was cranking for 2 mins before it would run on its own accord - but bit lumpy etc, but i was alive once again :D :D - the oil pressure was good as before
i tightened the clamp bolt as best i could - but was still able to rotate it albeit with more effort...so as i have the megajolt setup for the TR- i decided to buy a EDIS-6 module already wired up with the molex plug...just the coil pack\crank sensor and wheel left..
So next job will be complete the remaining 'Chrsitmas list' and recheck timing\tappet clearances..
But happy it started - but that was yesterday.....
any tips\pics for the crank sensor\ wheel setup would be helpful..
Ta
Manny
manny
Re: Manny's 78 GTE
Post by manny » Tue Mar 21, 2017 1:09 pm
Good day all,
my waaay over the top engine\body hoist.... :D :D
initially will be used to lift the body at the front ...then modified to lift an engine - its 90% finished - like most of the stuff i start
Ta
Manny
MikeT
Has thanked: 21 times
Been thanked: 25 times
Re: Manny's 78 GTE
Post by MikeT » Tue Mar 21, 2017 3:02 pm
Looks a useful tool ;)
I came unstuck with a loose dizzy in a similar way - I'm pretty sure I clouted it with the spare wheel, lol :oops:
Mike.
manny
Re: Manny's 78 GTE
Post by manny » Tue Mar 21, 2017 7:46 pm
MikeT wrote:Looks a useful tool ;)
Mike.
Hi Mike
yes...i read that in your post...mine seems reluctant to stay put :( .. need to check if a spring washer can be squeezed in there..although it frightens me to remove it...
BTW like the new wheels...i looked at a yellow one ( 2002) a few months back..but as i have no garage and live in Smethwick..decided against it...
Ta
Manny
Has thanked: 24 times
Been thanked: 105 times
Re: Manny's 78 GTE
Post by Coupe Racing » Wed Mar 22, 2017 2:58 am
This reminds me of a problem I had years ago
My distributor was loose so I tried to tighten the bolt
I kept applying more tightness to the bolt yet the distributor was still able to be moved slightly
Well then the clamping bolt sheared and I was left with the problem of stud extraction
The problem was this :
Over time the bolt had stretched and bottomed out in the block before it snapped
I would cut a thread or two off the bolt and see if you can achieve full tightness
Easy to remove with a magnet on a stick
manny
Re: Manny's 78 GTE
Post by manny » Wed Mar 22, 2017 7:54 am
Coupe' Racing wrote:This reminds me of a problem I had years ago
Good day Mr Racing
oooh that never occurred to me - but now you mention it - my clamp bolt has a recess for a flat head screwdriver as well?? ( not original?)- so the same affect could be achieved by a spring washer? i will remove the bolt\screw over the weekend
Ta
Manny
StevieF
Re: Manny's 78 GTE
Post by StevieF » Fri Mar 31, 2017 10:41 am
Hi Manny, my Dad owned ROE425M from new until 1995 - please don't say it's gone!!
manny
Re: Manny's 78 GTE
Post by manny » Fri Mar 31, 2017 11:00 am
Ooh I will find out if it still exists!!
Been thanked: 560 times
Re: Manny's 78 GTE
Post by Roger Pennington » Fri Mar 31, 2017 11:09 am
According to DVLA it's taxed and MOTed, so it looks quite likely? :D
oh and welcome to the forum, StevieF :)
manny
Re: Manny's 78 GTE
Post by manny » Fri Mar 31, 2017 1:31 pm
Roger Pennington wrote:According to DVLA it's taxed and MOTed, so it looks quite likely? :D
humm...my MOT chap who saw the car ( when i posted originally) - said it was 'in pieces...' but that could subjective i guess- but i am planning to meet up with the current owner in a couple of weeks.
Ta
Manny
StevieF
Re: Manny's 78 GTE
Post by StevieF » Fri Mar 31, 2017 10:30 pm
Thanks very much for the feedback and thanks for the welcome, a 60 year old woman suddenly attempting a forum is scarey all round..
My Dad was 39 when he bought the newly registered ROE425M in 1974 from 'Flights' in Handsworth (at the age of 17, I personally preferred the Datsun 240Z that was in the showroom at the time).
It was reluctantly passed on in 1995 when he retired and needed a more 'practical' car.
There are so many tales to tell.
My Dad is now 82 and was nearly lost to Mom and I last August but after a 13 hour op to rebuild his heart is making a spectacular recovery.
I know this is a ramble and I'm probably breaking all forum rules but I just wondered this morning where 'the Scim' was and found Manny's post - I frantically joined here in the hope that she's not quite gone.
So much heart.
Any updates would be much appreciated, thanks.
StevieF
Re: Manny's 78 GTE
Post by StevieF » Sat Apr 01, 2017 1:08 am
Manny, if she's not in too many pieces when you visit, photos would be great if possible. Thanks
manny
Re: Manny's 78 GTE
Post by manny » Sun Apr 02, 2017 9:21 am
Not a problem at all - I have asked my MOT father to get back in touch with the current owner
Ta
Manny
StevieF
ROE425M
Post by StevieF » Mon Apr 03, 2017 7:21 am
Very kind of you - we'll wait with bated breath! Dad was telling me about the various work he did on her over the years so if there's any info you need give us a shout!
Been thanked: 70 times
Re: Manny's 78 GTE
Post by Scimher » Thu Apr 06, 2017 4:30 pm
StevieF wrote:Hi Manny, my Dad owned ROE425M from new until 1995 - please don't say it's gone!!
...The maiden name of my ex-wife is 'Roe'...(Glad you've found your father's old car - best wishes...)
