Just Plain Silly!
Crouchie_b
Just Plain Silly!
Post by Crouchie_b » Thu Jul 17, 2014 6:20 pm
Well its 6 weeks since I won Jimmy's black SS1 Ti on the e-bay auction and 4 weeks since i picked it up. So it's about time to start a project thread and update on progress.
A bit of back ground to start off with...
I own a white SST that was pretty well known around the SSSC a few years back originally competing as a proper road going cat which was driven to the circuit and driven hard before it was driven home. As I improved it as a track car it got more & more competitive and was picking up pots on a fairly regular basis. Eventually the track improvements lead to the car being trailered to events as it was less drivable on the road. The shorter & stiffer spring rates meant speed bumps being crawled over at walking pace and anything less than a perfectly smooth road tending to loosen fillings!
Finally the car was taken off the road for a winter upgrade for an attack on the championship under the old Modified Production rules. Unfortunately this process has spiralled out of control & its now been 5 years since it saw a track. Even more ironically if i'd waited a year, SSSC adopted the MSA regs which would have suited the SST perfectly!
Anyway 'Mission Improbable' has been turned into a huge plug & is now waiting for space in the garage at Pete Brown's Skunk Works so we can build the single piece lift off front end with the refurbished chop gun we have.
The 5 year hiatus has lead to a growing itch which has eventually lead to the e-bay purchase of F795LLG without seeing it! Jimmy was very honest & open on the phone and a e-mail conversation confirmed that the ad was pretty straight so the grand sum of £1325 was handed over and the car driven onto the trailer (using the starter motor) before a long trip back from London.
The car was sold with the following known faults:
• No MOT
• The headlamps would continuously operate and wouldn't pack in either raised or lowered positions.
• Serious fuel leak on the return line
• poor paint work
• No antifreeze in the cooling system.
It also had some nice bits such as:
• new battery
• new re-cored radiator
• recon engine with only 30K since cam belt, water pump etc
• new front lower wish bones
• new front & rear springs
• new avo adjustable shocks front & rear#
• new rain tyres
• rebuild steering rack
• roll hoop & wind deflector
• good vinyl soft top
• seats recovered in Connolly leather
• a 2" thick file of all the bills & history for the 11 years Jimmy had owned it!
os fq.JPG (131.98 KiB) Viewed 3323 times
Crouchie_b
Been thanked: 64 times
Re: Building the Hot Hatch Hunter
Post by Nick » Thu Jul 17, 2014 6:41 pm
Sounds a cracking base for a Roadgoing Sprinter!
Crouchie_b
Cont: Building the Hot Hatch Hunter
Post by Crouchie_b » Thu Jul 17, 2014 6:56 pm
Having got it back from London the first job was fuel lines.
Searching through the history turned up a bill for the same job from a London based garage but when I looked it over there were leaks from the fuel rail to return plastic line & a less serious one at the tank to filler breather.
As they were all the same age, I replaced all the rubber lines with fresh and the return plastic with new .
The headlamp fuse was pulled, the lights wound up, the hand brake adjusted and she was booked in for an MOT with fingers crossed - The Result ---A pass with no advises!
So now on to the real work.
The inspiration for the car has always been to have a fast B road blaster that will surprise the yoot in their Nova's, 106's or whatever they are currently 'slamming' or whatever its called now (I know I'm getting old :roll: ). I want the car I had when I first started developing the SST, properly quick off the mark, good through the twisty bits but not so harsh that it knock your fillings out!
Craig Hughes' Hot Hatch Hunter article was always a great guide and most of the info he shared in the early days of the SST development is written up there on http://www.SS1Turbo.co.uk, hence the choice of title.
Next on the list will be the upgrades to suspension & handling.
Thanks for reading!
Crouchie_b
ptscim
Post by ptscim » Thu Jul 17, 2014 7:49 pm
Hi Brian, looks good mate :D good luck with it.
Phill.
(Leadfoot Morgan!)
RSSOC Speed championship competitor.
GTE mod prod class.
Present 5a.
Previous 2x 5a's, 6a and a competition prepared Se5.
Post by greeny » Thu Jul 17, 2014 10:56 pm
That sir sounds like a plan!
scimmy ben
Has thanked: 17 times
Been thanked: 11 times
Post by scimmy ben » Fri Jul 18, 2014 5:14 am
Not often you see a CA18ET with the pop off valve still present.
Is that a passenger side boost gauge?
choughton
Post by choughton » Fri Jul 18, 2014 1:01 pm
Looking good Brian. Interiors very smart 8)
Has thanked: 309 times
Been thanked: 233 times
Post by Corky » Fri Jul 18, 2014 8:00 pm
I love those seats !
The rest of the car aint bad either.....
MOT passed, Sounds like it's ready to compete at Curbs then :D
Been thanked: 49 times
Post by nickkeyser » Fri Jul 18, 2014 9:01 pm
I love this project, and I'm sure you'll execute it perfectly. A warmed up ss1 with fast road tweeks. What's not to love! It's somthing I've considered a lot, and 98% needs to stay standard to keep the charm and ease to live with.
Corky wrote:Sounds like it's ready to compete at Curbs then :D
There's a lot of peer pressure to be out at curbs!
What ever happens, we should get a pic of two black ss1's next to each other on lattice wheels.
SSSC Champion 2019
SS1 CVH 1600Ti
Crouchie_b
Post by Crouchie_b » Mon Jul 21, 2014 7:06 pm
The first thing to address was the suspension and braking.
The car was almost standard in this department with the exception of the AVO's & some upper wish bone poly bushes, so the first step was to use my spares from 'the shelf' and strengthen.
At the front, I had a spare pair of upper wishbones which I braced with some 1" box section steel from the rearward upper bushing mount up to the point that the shock mounts to and welded it in place.
This triangulates the loads from the damper into the whole wishbone assembly rather than the standard design which introduces a twisting moment in the wishbone. The modified ones already have the strengthening plate underneath inboard of the top ball joint mount so with the addition of the box these should now be able to handle the size of the pot-holes on our local B roads.
I carried out the same mod on the SST with some thin wall desk rail as it was lighter and this was tested with the much higher loads of stiffer springs, harder shocks & the stickier rubber that we use on track. They still look perfect, but with the HH Hunter being a road car weight is not such a consideration, and the 1" box was lying on the bench at the time, so it was nailed on!
After that they where powder coated and are now ready for the bushes to be added.
photo 4.JPG (327.26 KiB) Viewed 2921 times
Crouchie_b
Crouchie_b
Post by Crouchie_b » Mon Jul 21, 2014 7:19 pm
nickkeyser wrote:I love this project, and I'm sure you'll execute it perfectly. A warmed up ss1 with fast road tweeks. What's not to love! It's somthing I've considered a lot, and 98% needs to stay standard to keep the charm and ease to live with.
Exactly my point in doing it, the 2% may be a bit low but you can achieve alot with some subtle tweaks on the SS1. :wink:
- not really...I'm immune to the stuff now after years of gentle banter from 'the old loaf hauler' & the likes of Craig, Paul & Ben back in the days :lol:
nickkeyser wrote:What ever happens, we should get a pic of two black ss1's next to each other on lattice wheels.
ATM the paint is awful so it'll have to wait for another day I'm afraid, especially as I'm unlikely to be at Curborough this year again.
Crouchie_b
Has thanked: 449 times
Been thanked: 391 times
Post by CNHSS1 » Mon Jul 21, 2014 7:21 pm
Powder coat...*tart* ;-)
Edit:
Some gentle banter to make you feel one of the gang again Crouchie :-)
Crouchie_b
Post by Crouchie_b » Mon Jul 21, 2014 7:56 pm
CNHSS1 wrote:Powder coat...*tart* ;-)
its the Cheshire influence from the other side of the M62!
CNHSS1 wrote: Edit:
See told ya!
Crouchie_b
Crouchie_b
Post by Crouchie_b » Mon Jul 21, 2014 8:09 pm
At the rear another mod carried out on the SST was used which was to band the trailing arms.
This involves welding a 1" wide, 2mm thick steel band around the end where the hub mounting plate is welded to the end of the arm. It's this point which can tear under extreme side loads (mainly on track but a slide sideways into a curb will do it!) so it is as well the strengthen while I had the spares and the welder out.
More power-coating to finish!
photo 3.JPG (368.92 KiB) Viewed 2887 times
Crouchie_b
Post by greeny » Mon Jul 21, 2014 8:56 pm
Ooofff nice work liking the cheshire wishbones and trailing arms! Must sort the SST front wishbones out!
