Well here goes!
Been thanked: 70 times
Re: Well here goes!
Post by Scimher » Thu May 11, 2017 10:19 am
Looks great, Miles...[Love its living accommodation as well...]
Geoff.
Miles Burnett
Has thanked: 62 times
Well here goes!
Post by Miles Burnett » Wed May 30, 2018 5:16 pm
At last the chassis is rolling again ! Near rear brakes installed with refurbished drums. Front calipers will hopefully return from Biggred next week and then I’ll install new copper nickel brake pipes ( I kept the old ones as patterns). That’s the plan .......then the engine and gearbox !
Been thanked: 96 times
Well here goes!
Post by DARK STAR » Wed May 30, 2018 5:21 pm
That looks very smart.
Hope you haven't lost the body in the meantime 8)
Miles Burnett
Well here goes!
Post by Miles Burnett » Wed May 30, 2018 5:29 pm
Hi Chris, no the body is still sitting in the garage on one side and the engine and ‘box are sitting in the front half of the old chassis on the other side😉. So far I haven’t lost anything but there’s plenty of scope yet 😂. Desperately want the body on by the end of this year......work and family life keep trying to scupper that! Not that I’m complaining...
Miles Burnett
Well here goes!
Post by Miles Burnett » Wed May 30, 2018 5:40 pm
Proof the bodywork hasn’t moved :D
Diyhell
Has thanked: 96 times
Well here goes!
Post by Diyhell » Wed May 30, 2018 5:57 pm
That is looking particularly lovely! Somewhat envious of both its condition and the size of the garage!
SE6a needing lots of work...
Miles Burnett
Well here goes!
Post by Miles Burnett » Wed May 30, 2018 6:22 pm
I wish I could work on the car more often , but it’s steadily moving in the right direction. It’s easy to get disheartened sometimes. I’m trying to make the garage more comfortable during the winter as well, I find the older I get the more the cold gets into your joints 😂
Miles Burnett
Well here goes!
Post by Miles Burnett » Fri Dec 14, 2018 4:32 pm
Sometimes during a restoration it's the little things :D . Original early SE5 rear bump stops no longer available so with a template my local garage fabricated and tack welded a suitable backing plate to later ones supplied by QRG. Test fitted onto the original mountings and tomorrow clean up the mounting bolt threads ( from the powder coating) and fix them in place. Well pleased :-D
Well here goes!
Post by DARK STAR » Fri Dec 14, 2018 7:21 pm
Miles, you're back in action!
Great to hear from you.
Miles Burnett
Well here goes!
Post by Miles Burnett » Fri Dec 14, 2018 8:23 pm
Not massive amounts of action Chris more, petit à petit :D . You know how it is. Brakes all done . This is the last suspension part and I’m just in process of splitting eng/box to clean , replace clutch , inspect engine . Front bits of tin work just being blasted and powder coated. I am moving forward slowly but steadily . Hope all well with you.
Miles Burnett
Well here goes!
Post by Miles Burnett » Wed Feb 06, 2019 8:00 am
And yesterday .......Voila! Starting to look like a car again and now only taking up one car space in the garage. New engine crane has been worth its weight in gold :D . It really took some time fettling the exact position of the body but I got there!
Well here goes!
Post by DARK STAR » Wed Feb 06, 2019 12:27 pm
Very satisfying progress :)
As you say, it's starting to look like a car again ...
I was under the Coupé the other day and I thought 'wouldn't it be nice to have a chassis like Miles'.
Mine is virtually rust-free but not very pretty.
Been thanked: 559 times
Well here goes!
Post by Roger Pennington » Wed Feb 06, 2019 12:51 pm
That's starting to come together nicely. :D I think your comment about taking time to line up the body is probably very telling as to why many are slightly off - they simply didn't have the time in production, to get it exactly right.
Miles Burnett
Well here goes!
Post by Miles Burnett » Wed Feb 06, 2019 1:03 pm
I will check it is all ‘square’ one more time before I starting putting the bolts in place. I’m not quite sure what to work on next, but it’s probably heater box dismantling / rebuilding and the rewiring . At least with the body on it’s a great morale boost :) .
Well here goes!
Post by Roger Pennington » Wed Feb 06, 2019 1:21 pm
It's always been said that Reliant started with the heater, and then built the rest of the car around it! :lol:
