Sabre Turbo racer: 'Light Sabre'
Has thanked: 428 times
Been thanked: 370 times
Post by CNHSS1 » Fri Jan 03, 2020 12:59 am
Brian Crouch came round tonight and we cracked on with front suspension fabrication. All the fabrications done, just an upper damper mount to be welded on but ive had to order as id run out of the ize to match other side.
Some nore spacers and 1/2" cap head bolts ordered.
Offside hub and upright to be fitted at the weekend and the car will roll again, and i can turn it around in the garage and start on rear suspension mods and trailing arm strengthening.
Thanks as ever to Brian, hes a good bloke, top banter and does his best to impart some of his massive engieering know how, cheers BC, youre agood egg 8) 8)
Post by CNHSS1 » Sun Jan 05, 2020 7:39 pm
So, didnt get back from rugby until 230ish, so quickly finished the front end fabrication, and out wheels back in and wheeled unto daylight, 1st time in 3 years! Turned around and set about stripping rear.
Lot of minor GRP damage from the 'brush' with the tyre wll after my Wiscombe off, but that can all wait.
Removed all wiring from rear end, removed rear ARB, and cleaned and sprayed trailing arm and diff cradle bolts, for removal later in the week 8) 8)
Has thanked: 102 times
Been thanked: 153 times
Post by reliant-reviver » Sun Jan 05, 2020 8:17 pm
"removed rear arb"
with your favourite tool by the looks of it :roll:
Amused to see my sticker amendment is still there, had forgotten about that :lol:
Good progress.
Post by CNHSS1 » Sun Jan 05, 2020 8:26 pm
"removed rear arb"
Good progress.
Yep, used my electrical universal spanner :mrgreen:
Love the sticker, may get it replicated when the cars finished 8)
Post by CNHSS1 » Sun Jan 05, 2020 8:50 pm
Had help... No.1 son, Finn, helping out :D
Has thanked: 195 times
Been thanked: 104 times
Post by efi_sprintgte » Sun Jan 05, 2020 9:04 pm
Great work, a file seems abit subtle for the CNH blood line..?? :D
Post by CNHSS1 » Sun Jan 05, 2020 9:09 pm
Im starting them off gently, angry grinder, die grinder, plasma cutter and gas axe are for when hes 12... :lol: :lol:
Has thanked: 78 times
Been thanked: 707 times
Post by philhoward » Sun Jan 05, 2020 9:11 pm
I reckon it’s psychology - get him to do the first one by hand, then “look how much quicker it is with a soft pad in a grinder..” :mrgreen:
Been thanked: 129 times
Post by BigBobPilot » Mon Jan 06, 2020 4:09 pm
Good to see the progress. You're spurring me along, I really need to clear my workshop so I can get on with the mods on my SS1...
SS1 CA18DET race car
Post by CNHSS1 » Mon Jan 06, 2020 6:56 pm
To be fair, its your ss1 thats spurred me on, but im enjoying building a racer again 8)
turbster
Has thanked: 65 times
Been thanked: 56 times
Post by turbster » Tue Jan 07, 2020 7:03 pm
Nice to see this one progressing again 👍
LRP 335E SE4a
XRF 976H SE5
www.gtevolution.co.uk
Post by CNHSS1 » Tue Jan 07, 2020 8:11 pm
Its all you and Goughs fault Tango, cant have my old sparring partners out playing and not be able to play too :wink: :lol:
Post by CNHSS1 » Fri Jan 10, 2020 12:16 am
So we had the full Thursday night Team meeting in the Hughes Man Cave, myself and Crouch's Junior and Senior respectively.
Stripped rear suspension off, and removed diff cradle and diff. Rear trailing arms are already polybushed and strengthened, but as im changibg to rosejoints, seems a shame to butcher the arms, so am flogging the Sabre arms and will modify a spare pair i have courtesy of Darryl Crosby 8)
Few pics...
Post by CNHSS1 » Fri Jan 10, 2020 12:20 am
Next job is to split the rear panel from the tub. Theres only about 500mm still attached, needs a tickle with a multi tool and itll come free making access so much easier. The tub is bonded to the rear deck at the factory but the are seperate mouldings
scimmy ben
Has thanked: 17 times
Been thanked: 11 times
Post by scimmy ben » Fri Jan 10, 2020 7:15 am
Are you replicating Batmobile ones? Any thoughts on changing chassis mounts?
