Sabre Turbo racer: 'Light Sabre'
Has thanked: 417 times
Been thanked: 351 times
Post by CNHSS1 » Sun Nov 26, 2017 10:39 pm
The auto bellhousing has a centre hole and the main gearbox bearing is round of course so a case of centering on that
Post by CNHSS1 » Sun Nov 26, 2017 10:40 pm
Mdf pattern is basic but you get the idea
Has thanked: 32 times
Been thanked: 50 times
Post by Alan SS1 » Mon Nov 27, 2017 12:38 pm
Liking the tubular wishbones / suspension :D won't pass an MoT though, bit light on the tyre tread
springs are with the shocks (I assume)?
Post by CNHSS1 » Mon Nov 27, 2017 12:49 pm
not road legal anymore so don't have to worry of constaints of an mot :D
On Batmobile I ran pure coilovers but with the sabre being heavier wanted stronger fabricated upper wishbones when i convert that sabre to pure coilover
Post by CNHSS1 » Thu Nov 30, 2017 10:51 pm
Concentric clutch cylinder arrived :mrgreen:
Been thanked: 123 times
Post by BigBobPilot » Fri Dec 01, 2017 10:42 pm
Looks like you went for the Burton one then.
SS1 CA18DET race car
Post by CNHSS1 » Sat Dec 02, 2017 12:57 am
Brands Hatch Performance, 155 quid
Has thanked: 316 times
Been thanked: 155 times
Post by MikeyBikey » Sat Dec 02, 2017 9:20 am
I put concentric on a focus recently. Its a good idea. it is simply more evenly applied pressure ?
Has thanked: 181 times
Been thanked: 98 times
Post by efi_sprintgte » Sat Dec 02, 2017 11:49 am
Used one on my type 9 when I had a 2.9 cologne in my 5a. Lovely clutch operation.
Post by CNHSS1 » Sat Dec 02, 2017 12:37 pm
I can't take the credit, merely nicked the idea from Bigbobpilot whos used them on a few of his racers. Also means less to find clearance for around the bellhousing
Post by BigBobPilot » Sat Dec 02, 2017 1:08 pm
And you're using an auto bell housing that doesn't normally accomodate a clutch.
One thing to check, the Mondeo release bearing is flat, does this match the Nissan one? If the Nissan one is rounded, you'll need to change the bearing on the Mondeo concentric cylinder. Otherwise the bearing will wear the clutch fingers away.
Post by CNHSS1 » Sat Dec 02, 2017 1:50 pm
Hmmm hadn't thought of that, the Nissan has a raised section iirc, will dig one out and take some pics
Post by CNHSS1 » Fri Dec 22, 2017 8:23 pm
Broken up from work tonight! Yay!
Hopefully get some progress on Sabre over next week or so, few new parts bought, just need some man-cave time :-)
Er Indoors got a new motor too. Picked it up as it snowed, so the 4 wheel drive helped whilst mine sat buried!
Has thanked: 100 times
Been thanked: 150 times
Post by reliant-reviver » Fri Dec 22, 2017 8:29 pm
Would you like to borrow some i's?
BiKiNi
Post by BigBobPilot » Fri Dec 22, 2017 9:46 pm
Are you opening a Beemer dealership?
At least the real car is tucked up inside, out of the snow.
