Sabre Turbo racer: 'Light Sabre'
Has thanked: 207 times
Been thanked: 102 times
Post by MikeyBikey » Tue Nov 07, 2017 8:29 pm
CNHSS1 wrote:
Mon Nov 06, 2017 10:28 pm
efi_sprintgte wrote:
Mon Nov 06, 2017 9:44 pm
Is that some form of quick release gearbox your developing??
I think you and mikey should see who can do the worst damage to a gearbox :D
As for Mike and I, at least I can keep oil in mine :lol:
Last year I destroyed a type 9. My large mother in law got in the car and i think it sheared a few teeth trying to carry her uphill. i darent open it but now the challenge has been set i will video the opening of the box and tipping the bits out...
Been thanked: 63 times
Post by BigBobPilot » Wed Nov 08, 2017 5:45 pm
Good work. Engine & gearbox out again. Have you been counting how may times you've done this well practiced routine?
SS1 CA18DET race car in build
Has thanked: 277 times
Been thanked: 234 times
Post by CNHSS1 » Wed Nov 08, 2017 5:57 pm
I think this is the 5th time with the sabre :-(
Post by BigBobPilot » Wed Nov 08, 2017 6:27 pm
Double figures soon then!
Post by MikeyBikey » Wed Nov 08, 2017 7:48 pm
I think it's a weight issue, like my mother in law :W
Post by CNHSS1 » Wed Nov 08, 2017 8:06 pm
Four cough Mike :mrgreen:
Post by CNHSS1 » Wed Nov 08, 2017 8:07 pm
Hope not, hoping to have a little less gearbox intimacy with this conversion
Post by CNHSS1 » Sun Nov 12, 2017 3:14 pm
Mocking up adaptor plate to box and bellhousing. Currently in mdf to prove clearances and then get machine shop to make the plate and do the welding and machining
No1 slave roped in too
Post by CNHSS1 » Sun Nov 12, 2017 3:16 pm
Anyone know a decent machinist? Preferably Midlands based?
Been thanked: 89 times
Post by gtcse8 » Sun Nov 12, 2017 4:58 pm
:? What material is required? :roll:
Post by CNHSS1 » Sun Nov 12, 2017 5:00 pm
Aluminium as potentially the adaptor plate will need to be welded to the Nissan bellhousing
Post by gtcse8 » Sun Nov 12, 2017 5:21 pm
Ok Craig
be careful on spec as there are a few types of aluminium out there, some are weld able but may crack.
The alloy casting may not be acceptable to TIG welding either.
Could not countersunk allen screws be used??, it would also make any changes reversible and alterable in future??.
If you can`t find anyone nearer to you I could look into it for you?.
Post by CNHSS1 » Sun Nov 12, 2017 6:16 pm
Thanks Mark.
Bellhousing is weldable alloy luckily.
There's a possibility of a steel plate with csk bolts, just preferred welded so that nothing moves or comes loose.
If I can't find anyone local I will take you up on the offer, cheers :-)
Post by BigBobPilot » Sun Nov 12, 2017 8:22 pm
Did you get the box, bellhousing & block bolted up?
Post by CNHSS1 » Sun Nov 12, 2017 8:40 pm
Yup will email you pics mate
