At last! I have my SE5 back!
Akuchanny
Post by Akuchanny » Mon Jun 24, 2019 11:50 pm
Hi Guys, thanks for the kind wishes,
I did have a few boxes of parts arrive last week so am hopefully going to get started on the car again soon. First plan is to repair the body damage and lower the floors, Has anyone done this on a se5 before? as I need some extra head room whilst I'm in the car. The plan is to put some Mk2 mxd seats in the car as well, I may shave the seat foam on the bottom by about an inch, but that depends on how they fit. Again does anyone have any pointers for which runners to use, or how to cut down the original runners.
Finally some little F***** has broken the rear boot hatch hinge. I am trying to see if there is a way that I could drill out the plat and use a bolt to secure the hinge back, as I don't really want to pull the headlining and glass in a new hinge. does anyone have any ideas about that as well?
thanks again for all the support and I am looking forward top hopefully having the car back on the road soon.
Andrew Kuchanny - 2530
London
71' SE5
61' Morris Minor
Has thanked: 24 times
Been thanked: 105 times
Post by Coupe Racing » Tue Jun 25, 2019 4:25 am
The exhaust will be the biggest hurdle to lowering the floor.
Akuchanny
Post by Akuchanny » Wed Jul 03, 2019 9:28 pm
I guessed the exhaust would be the issue, I am hoping to get about 1cm if possible maybe 2, just to give me a little more head room. Has anyone tried it on a se5 before?
London
71' SE5
61' Morris Minor
IanC
Has thanked: 54 times
Post by IanC » Thu Jul 04, 2019 8:55 am
I had this issue on a SE5a, I cut the broken pin out and replaced it with a short length of 6mm threaded rod, with a nut on either side of the right angled part of the glassed in bracket.
Ian
hatch hinge repair
Current : SE5a 4spd auto
Akuchanny
Post by Akuchanny » Wed Jul 17, 2019 4:55 pm
Thanks Ian.
Thats kind of what I had in mind, so have a reference to work from.
had a few calamities today, the brass tee sender sheered off in the 'new' block today and the removal tool destroyed the thread. So I am now planing on swapping the air intake manifolds over, although the new black is a later engine than the one in my 71' se5 so fingers crossed that will work.
I have realised the sump is now at the rear of the new block and wondered if anyone has found an issues with this when swapping?
Many thanks again
Andy
London
71' SE5
61' Morris Minor
Has thanked: 77 times
Been thanked: 706 times
Post by philhoward » Wed Jul 17, 2019 5:23 pm
Expect problems if you mix an oval port and D port inlet (head and manifold mismatch) - you'll end up with an air leak..
A rear sump engine can be converted to a front sump (swap sump, pump pick up pipe and front cover, block up the now redundant dispstick tube). I can't remember if the dipsticks are different off the top of my head. I'm not sure if you can do it the other way round though..the hole might not be there to fit a dipstick (sometimes it has a small core plug in it) and if it happens to be a VERY early V6, I don't think the oil pump pickup can be swapped either.
Akuchanny
Post by Akuchanny » Wed Jul 17, 2019 9:29 pm
Thanks Phil,
From memory of the last top end rebuild the heads on the original engine are D port so I'm guessing the manifold must be d port as well. Do I have to switch all the part and the sump over? or will it fit as is? I have been unlucky (sometimes from over enthusiastic help) with this engine, as even the Dizzy had stuck solid and had to be persuaded out. Luckily my electronic unit will replace it as it didn't far too well in the removal.
The Original block has a dip stick that comes out of the block next to the oil pressure gauge pipe, and the front cover seems to have only the pulleys and mounts for pipes on it. I am still trying to get rid of any source of swarf (again over exuberant help today). I am having trouble removing the old heater control valve as its looking a bit ropey but its just spinning on a nut and loose on the fitting at the rear now - does anyone have a fix for this?
Also does anyone have any leads on a heater blower motor, mine died a while ago and now seems like a opportune time to swap it as nearly everything is out of the car's engine bay.
Also I need to replace the. gearbox rear oil seal, does anyone have a way to remove this from the box, its a four speed with overdrive.
I am hoping to - if nothing else too major goes wrong, have the car running before September, fingers crossed. I then need to try and make the car pretty again.
Well I am off to no doubt be told how "expensive cars are" with that irritating look by my girlfriend when I pick her up, although I have a feel the car maybe cheaper than her in the long run :D
London
71' SE5
61' Morris Minor
Post by philhoward » Wed Jul 17, 2019 9:42 pm
I’m a bit confused..
Inlet manifold and heads must match
Sump/oil pickup/front cover must match to a degree - you can leave a front sump-spec front cover on but you’ll need to block the dipstick tube off..
The two statements aren’t mutually inclusive - you can have a front sump setup with D-port inlet, oval port with rear sump or any combination as (generally) they don’t interfere with each other.
Have another look at the dipstick - I think you’ll find it’s oart of the front cover. If not then it’s a new one on me - please take a picture!
Akuchanny
Post by Akuchanny » Wed Sep 25, 2019 11:41 am
So the oil dip stick was on the front cover - its was so full of gunk you couldn't see any joins, so the front cover and the pulley are off the original engine now, and have been painted up. The heads on the old engine must have been changed as they are D port from memory so hopefully switching inlet manifolds won't be a problem, although I was thinking of just getting a replacement manifold if I could find one, although most on eBay have looked like they have been under the sea for a while!
My plan is to break down and store the original engine so its easier to store, although Im not sure if or when I will swap it back, but id rather be safer than sorry. as I don't currently have a engine stand I am just taking a quick break and planing what to do next. I think break down the original block and then have the parts I need ready is a good move, before flushing out the replacement and switching over the front cover and the sump, and the oil pick up as well as the inlet manifold - unless anyone has a lead on a inlet I can have if they have one going?
Just wanted to double check that I only need to switch the oil take up and the sump and the front pulley cover - any ideas how to block off the block mounted dip stick tube ?
Andy
London
71' SE5
61' Morris Minor
