- RSSOC Member
- Been thanked: 29 times
Post
by BigBobPilot » Tue Dec 12, 2017 11:38 pm
superleggo wrote: ↑Tue Dec 12, 2017 11:15 pm
Just to keep Big Bob happy! I picked up some new M10 x 50mm bolts with a smooth section...
I feel happy!
SS1 CA18DET race car in build, see: "551 a race oddity" in Project Progress
CSCC "Swinging 60s" race series winners in 2011, 2014 & 2015 (Group 2) sharing a Marcos with Iain Daniels
fightingtorque
- Has thanked: 11 times
- Been thanked: 3 times
Post
by fightingtorque » Tue Dec 12, 2017 11:52 pm
Looks great. I need to build some new exhausts for mine. Spending time to get it well supported but close to the chassis, as you have done, is key because there isn't much room under a Scimitar epecially when lowering is planned.......
fightingtorque
superleggo
- Has thanked: 8 times
- Been thanked: 9 times
Post
by superleggo » Fri Dec 15, 2017 11:20 pm
Fightingtorque - There is more room for the exhausts than you think. I set the ride height of my chassis at the standard height to give me a working reference. This means that the main chassis rails are 7'' off the ground. The centre box on my system is the lowest point at 6'' so is only 1'' lower than the chassis rails. There is a lot of room under the front seat wells and if I had not decided to have been a bid kid with the exhaust diverted system I could have got in a much bigger centre box round or oval. This box could go up an inch with ease if you kink the pipes upward into the seat well and then back down to clear the centre support for the out rigger. My pipe is 2.25'' which should be good for 300hp. Good luck with your system. I have enjoyed the challenge of mine.
I have not been a great fan of the position of the coil pack on the Omega engine.They apparently have a bit of a reputation for failure so I decided to investigate the possibility of re-positioning it to the front of the engine.
- 2017 dec 15th 0021.JPG (151.15 KiB) Viewed 624 times
It looks a possibility even reusing the old plug leads.
- 2017 dec 15th 0022.JPG (190.68 KiB) Viewed 624 times
Plug lead 4 is a little short but workable.
Onto the cam belt change. I may as well do the water pump as they are quite cheap and will be easy now.
- 2017 dec 15th 0024.JPG (200.82 KiB) Viewed 624 times
superleggo
superleggo
Post
by superleggo » Sun Dec 31, 2017 12:10 pm
A friend came over to help change the cam belt as he does them all day and I did not want to get it wrong.
- 2017 Dec 26th 001.JPG (185.05 KiB) Viewed 503 times
I have been looking everywhere for an new connector for the fuel filter to complete the fuel line. One arrived from China for 99p as an early Christmas present.
- 2017 Dec 26th 001 (2).JPG (144.15 KiB) Viewed 503 times
I cut the fuel hoses with disc cutter but was surprised to find how many rubber bits are left in the fuel line.
- 2017 Dec 26th 002.JPG (98.75 KiB) Viewed 503 times
I was glad I washed them all out before installation and allowing the bits to get to the injectors.
Happy New Year
superleggo
superleggo
Post
by superleggo » Sun Dec 31, 2017 12:17 pm
The fuel tank came with a free hole where the breaker had drilled it to empty the tank. I was going to fit a drain plug to block it off but it did not work out too well so I decided to weld it up after washing it out very carefully and filling with exhaust fumes to make sure there was no chance of any petrol fumes left.
I all worked out ok with a bit of care and a gas soldering torch.
- 2017 Dec 26th 001 (3).JPG (163.45 KiB) Viewed 502 times
superleggo
superleggo
Post
by superleggo » Sun Dec 31, 2017 7:07 pm
I thought I would add one more bracket to the exhaust for the diverted pipe to add a bit more support. So I fabricated a new bracket and welded it to the chassis. After a quick paint it looks good to go.
- 2017 30th Dec 002.JPG (145.46 KiB) Viewed 480 times
- 2017 30th Dec 001.JPG (168.19 KiB) Viewed 479 times
Well I think that is all I can do with the body off so time to talk some mates into lifting the shell back on.
superleggo
superleggo
Post
by superleggo » Thu Jan 11, 2018 11:59 pm
I have done nothing about the brakes yet but need to start thinking about it in more detail. Do I refurbish what is there or is there a good upgrade for the front.
I have never driven the car so no idea what the standard brakes are like but with the engine upgrade it seems logical to sort the brakes as well.
I think I have seen disc conversion brackets advertised for the rear.
Any thoughts welcome.
superleggo
- RSSOC Member
- Has thanked: 142 times
- Been thanked: 73 times
Post
by MikeyBikey » Sun Jan 14, 2018 11:18 pm
superleggo,
What number are you on. I’ll give you a call re brakes. I have fitted wilwoods and vented discs on the front and discs on the rear, of my 5a.
superleggo
Post
by superleggo » Sat Feb 17, 2018 8:39 pm
Mikey
Thanks for the contact I will give you a ring.
I took the pedal box the pedal box to pieces as it was seized and the pedals were not moving well. Also the return spring on the clutch was broken.
- 2018 Feb 12th 002.JPG (150.16 KiB) Viewed 227 times
- 2018 Feb 12th 004 (5).JPG (160.64 KiB) Viewed 227 times
I have got a good master cylinder but wondering what options there are for a split system or should I fit balance bar which seems a lot of effort?
I was told GTE brakes are fine as standard unless you use it on the track. This will be a road car so any thoughts?
superleggo
- RSSOC Member
- Has thanked: 37 times
- Been thanked: 457 times
Post
by philhoward » Sat Feb 17, 2018 8:41 pm
Mine was never an issue - even with scimjim in “test pilot” mode.. certainly wasn’t an issue with over a ton of cars van on the back either.
Previous: SE5/5a/SS1 No.1/SS1 Rooster/SS1 1800Ti/
SE5a 24 Valve
DarrylWebb
- Has thanked: 70 times
- Been thanked: 39 times
Post
by DarrylWebb » Mon Feb 26, 2018 10:10 pm
The bias box I fitted was an unneccessary complication, but I'd run out of space for the remote servo. I didn't choose it for any doubt of the standard braking perfromance, as I'd read much the same as you.
DarrylWebb
