Has thanked: 309 times
Been thanked: 233 times
Post by Corky » Sat Feb 01, 2020 9:18 pm
Cage now in, doors and roof back on.
Been thanked: 132 times
Post by BigBobPilot » Sat Feb 01, 2020 10:11 pm
That looks much better with the full cage in!
SS1 CA18DET race car
Post by Corky » Wed Feb 05, 2020 6:17 pm
A few more jobs ticked off.
Replaced the brake fluid reservoir as it had cracked after coming into contact with the bonnet. I've raised the bonnet a few mm by packing out the catches, and I've cut out the offending chunk of bonnet underside. A quick check with the inspection camera confirmed the two were no longer touching.
Wheels are now on the rear, and low and behold they're a perfect fit with no need for spacers. I dropped the rear shocks so I could check full articulation, and the arches only needed a mild tickle to give enough width. So it's now sporting chunky 215 tyres all round.
Has thanked: 33 times
Been thanked: 51 times
Post by Alan SS1 » Wed Feb 05, 2020 6:34 pm
Steve,
looking very tidy and up to your usual high standard , especially for a 'racing' version, even if road-going :shock:
I don't know where you find the time and enthusiasim !!
Dcrosby13
Has thanked: 34 times
Been thanked: 103 times
Post by Dcrosby13 » Wed Feb 05, 2020 8:28 pm
Those really suit the car, nice work
I break stuff...... :w
Has thanked: 448 times
Been thanked: 391 times
Post by CNHSS1 » Wed Feb 05, 2020 9:22 pm
I like your attention to detail Steve, thats a cracking 'built to the regs' car, super impressed 8)
Benc
Has thanked: 96 times
Been thanked: 52 times
Post by Benc » Thu Feb 06, 2020 8:07 am
Potentially another Cheshire winner :lol: :mrgreen:
Post by Corky » Thu Feb 06, 2020 1:05 pm
Definitely, but it's not concours I've built it for. :lol:
Post by Alan SS1 » Thu Feb 06, 2020 5:57 pm
ruddy heck, glad I don't do concours if that's your 'it will do effort for a racing machine' !!!!
pretty sure you'd pick up prizes with that , as long as no points removed for 'period modifications' :wink:
Post by Corky » Thu Feb 06, 2020 6:54 pm
Just for completeness, a couple of the replacement reservoir. It sits on top of one of my 22mm master cylinders, which puts it a bit closer to the underside of the bonnet.
I've also been busy fixing the trailer. I had a couple of brake lock ups, and found the problem to be this hitch damper.
Just Plain Silly!
Post by Corky » Sun Feb 16, 2020 2:47 pm
split from another thread
Crouchie, I'm trying to fit a Canadian manifold to my spare engine, as you've done. I'll be using the stock ECU when this engine eventually finds its way into the car, which means I'll be using the CA20e IAA valve thingy and IAC from the CA18ET (I think). I'm getting a bit hung up on what to connect where, so was wondering if I can be cheeky and ask for a few photos of what you've done :mrgreen:
Easier to follow than trailbaze..... :wink:
Crouchie_b
Just Plain Silly!
Post by Crouchie_b » Mon Feb 17, 2020 8:45 pm
Corky, both engines with the inlets on are at Paul’s atm so not sure when I can get the photos done.
May be there in the next couple of weeks but I don’t have a problem with Paul taking some for you if you need
Also could be wrong but i think Craig had the install instructions?
Crouchie_b
Just Plain Silly!
Post by CNHSS1 » Mon Feb 17, 2020 9:52 pm
The ones i imported never came with instructions, but i have pics Corky and there were some diagrams on zxoc iirc the US site under the ca20 section. A lot is commone sense, all the EGR junk can be lost.
Just Plain Silly!
Post by Corky » Tue Feb 18, 2020 8:13 am
Thanks fellas. I'm happy with about 90% of it. The three I'm not sure of are the flow and return to the IAC (the ca20 IAA doesn't have these) and the IAA outlet. Maybe I just need to make up a manifold that brings all three together?
Just Plain Silly!
Post by CNHSS1 » Tue Feb 18, 2020 8:17 am
Ill dig out pocs and info i have over next day or so Corky :)
