Has thanked: 154 times
Been thanked: 1051 times
Corky's Scimitars & S2K
Post by scimjim » Mon Dec 16, 2019 8:29 pm
Benc wrote:
Mon Dec 16, 2019 8:18 pm
swoakes wrote:
Mon Dec 16, 2019 8:02 pm
Benc wrote:
Mon Dec 16, 2019 7:36 pm
Did you manage to check the offset?
My Wellers and I suspect Corky's too are ET15 8x13 unless he has purchased some new ones :?:
On weller website they only quote 3,-10&32 for offset....
https://wellerwheels.com/collections/mo ... streetrace
Don’t buy from Weller, check George polley motorsport.
viewtopic.php?f=17&t=26762&p=369014&hil ... ey#p369014
Benc
Has thanked: 94 times
Been thanked: 52 times
Post by Benc » Mon Dec 16, 2019 8:37 pm
Studying the photo in more detail I think you get Weller 03/15 4x100 and I think 9023/2. Could the 03 be what Weller are quoting? I’ll ring round tomorrow to check.
Has thanked: 294 times
Been thanked: 228 times
Corky's Scimitars (Idle Control Valve issue)
Post by Corky » Tue Jan 14, 2020 9:52 am
Lots going on at the moment.
I pushed the sill back into place (1.5cm) following the "slight orf" at Loton. I used Craig's hydraulic ram to do the pushing (brilliant piece of kit), and then I opened up the sill like a tin can and pushed the face out with a crow bar before welding the hole back up. Looks like it worked, but the sill surface is like the Himalayas not my usual standard of finish, but it'll do for MOT and racing purposes.
I'm also waiting for some metal to arrive so I can weld in the feet for the front of the roll cage.
I've also picked up a CA20E inlet manifold, which I'm in the process of fitting to the engine I've been rebuilding (for 2 years :oops: ) . The only snag that I'm having difficulty with is the Idle Control Valve. I don't have a CA20E one (if it actually exists at all), and the CA18ET one does not fit. I understand that it's not required if I go down the aftermarket ECU route, but I don't plan to do that just yet.
So, will it work with this manifold if I make some sort of sandwich plate adaptor (which I think I can do with 10mm ally plate)? Or will it only work with the smaller CA18ET manifold?
Photos (some of which may be upside down, now on Android phone but posting from a Mac...)
Dcrosby13
Has thanked: 30 times
Been thanked: 89 times
Post by Dcrosby13 » Tue Jan 14, 2020 10:00 am
Sorry man I must have given you the wrong one, The CA20E one should be on the shelf somewhere, I will dig it out and post it to you.
I break stuff...... :w
Post by Corky » Tue Jan 14, 2020 10:06 am
That would be great, cheers Darryl.
I thought maybe the one you'd given me hadn't been fully tried out :lol:
Dcrosby13
Post by Dcrosby13 » Tue Jan 14, 2020 11:39 am
it came as a complete unit, unfortunately I did my usual trick of pulling it apart immediately, I will be around somewhere I just need to dig it out.
Dcrosby13
We wont be running an idle valve anyway so I will send you everything I have.
Dcrosby13
Post by Dcrosby13 » Tue Jan 14, 2020 11:40 am
Also you might want to look at upgrading to a DET throttle body and swap the ET TPS onto it as the DET is a potentiometer opposed to the ET's on off switch.
Post by Corky » Tue Jan 14, 2020 3:34 pm
If I go to an aftermarket ECU then I'll do that.
As it stands, I just want to get this engine built up and running on the stock ECU and hopefully find a couple of horses and a few torques.
Any bits you pulled off the manifold will be much appreciated :mrgreen:
Crouchie_b
Has thanked: 39 times
Post by Crouchie_b » Wed Jan 15, 2020 8:28 pm
From memory I had mine fitted but it wasn’t plugged into anything and may have the vacuum hoses blanked? I’ll try to check it when I lay my hands on it.
Crouchie_b
Has thanked: 428 times
Been thanked: 367 times
Post by CNHSS1 » Wed Jan 15, 2020 9:02 pm
If the originl cant be obtained, a thick alloy plate made up to adapt the stock one to CA20 manifold could be used, or one off another car. Stew B fitted a ford one to the Sabre when he had it, was remotely fitted with hose rather than bolted to fannymold
Post by Corky » Thu Jan 16, 2020 1:50 pm
Thanks fellas, DC has now found the aac valve so this shouldn't be a problem now. He was also good enough to include a coolant connector tree that Steve had fabricated, as the original is in the way of the manifold. I just need to sort out an oil cooler take off and I'll be almost there with the mock up.
Post by Corky » Thu Jan 16, 2020 1:56 pm
Just in the process of fabricating the roll cage foot plates which I'll weld onto the sills tomorrow (photos later).
And in wheel news, these arrived yesterday.
13" 7J ET25 and just 4.5kg per wheel.
Post by Corky » Thu Jan 16, 2020 3:49 pm
Making progress with the cage support brackets. My welding isn't very neat, but passes the hammer and jump test with flying colours.
Has thanked: 77 times
Been thanked: 706 times
Post by philhoward » Thu Jan 16, 2020 4:13 pm
That beats trying to evolve triple jointed wrists...
