Corky's Scimitars
Benc
Has thanked: 36 times
Corky's Scimitars (....currently sprint car fettling )
Post by Benc » Thu Apr 12, 2018 9:03 pm
https://www.carbuildersolutions.com/uk/ ... utter-trim
Looks like it will do the job but would need to remove the lip on top edge?
Has thanked: 138 times
Been thanked: 149 times
Post by Corky » Thu Apr 12, 2018 9:41 pm
Ah yes, I saw that whilst hunting. But I discounted it, as it’s not really wide enough for my liking. It needs to be about 10-15mm wider to sit flush against the door-seal lip. Very close though.
PeterSM
Been thanked: 24 times
Post by PeterSM » Sat Apr 14, 2018 9:51 am
Steve what have you used for the seal at the top of the window sealing the window to the hardtop?
Peter Smith
SS1 Sprint Car, 1800Ti SS1 and a very special Sabre DET
Post by Corky » Sat Apr 14, 2018 11:38 am
Do you mean the little rubber wotsit that pushes into the quarter light or the seal along the edge of the hard top?
PeterSM
Post by PeterSM » Sat Apr 14, 2018 2:21 pm
I meant the seal along the top but now you mention it the wotsit as well!
Peter Smith
Post by Corky » Sat Apr 14, 2018 2:32 pm
The wotsit is a standard part, available as reproductions from GW (circa £15 a pop last time I asked).The other seal is just a length of standard door seal (probably what I had left over from a GTC rebuild).
td99
Been thanked: 22 times
Post by td99 » Sat Apr 14, 2018 6:22 pm
I think the wear of the "Wotsit" if that's the bit or rubber at top of quarterlight is non-essential. It's all to do with does the window glass seal up against the rubber seal of the hard/soft-top
I've had old and new "Wotsits" and really the difference in Zilch. Glass needs to close against rubber of hard/soft top.The Wotsit prevents a small air gap that can cause noise at high speed, but then only appropriate for a concours/sunday-afternoon car as at any speed it will not figure in general ss1 noise.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Post by Corky » Sat Apr 21, 2018 5:42 pm
Not much to report.
I've rebuilt the turbo I took off the car. The oil rings were shot and the journals were worn. I had a look to see if I could find a new compressor shaft, but couldn't find anything that categorically said it would fit my turbo, so just rebuilt it with the original. There's less play in shaft, so it'll do as an emergency spare should I need one.
I've stripped the car's original engine (yes the one I sold and then bought back), and I'm in the process of fitting new shells and piston rings. Once built, I'll pair this with the MK2 gearbox I've fitted an modified S13 quick shifter to.
And today, I've rebuilt the hard top. Removed the alloy trim from the bottom edge (I didn't have the insert to go with it) and fitted some edge trim. Fitted an MGB hood seal (I think it's a bit thick but gives a very good seal). I just need to fit some gutters (pending some innovation by another forum member :D ).
Benc
Post by Benc » Sun Apr 22, 2018 10:33 am
How did you attach the head seal to the hardtop?
When at Croft I had a drip coming in above the quarter light frame is there a mod to stop that leak?
Post by Corky » Sun Apr 22, 2018 10:54 am
I attached the seal with some evo-stick contact adhesive. But before I did that I cut the bead off the bottom of the seal to reduce the depth. I also cut, re-shaped and super-glued the ends of the hood seal to round them off.
The quaterlight leak is a feature.... :lol: It can be improved if you have a bit of give in the hood to stretch it around the gap and re-glue it to the header rail. When I finish putting the hard top on, I will be using some silicone in the area between the door and hood seals.
Has thanked: 22 times
Been thanked: 83 times
Post by swoakes » Sun Apr 22, 2018 11:18 am
Is it a trick of the light or have you sat on that hard top Corky......Looks to be an imprint of your ar$e front middle :lol:
Post by Corky » Sun Apr 22, 2018 11:21 am
Busted.... :lol:
Post by Corky » Sun Apr 22, 2018 3:57 pm
.......and knocked a couple of these up to secure it at the rear. Just need to neaten them up a bit and shorten the bolt.
Post by swoakes » Sun Apr 22, 2018 4:05 pm
Took my top off to re-seal the rear window. I don't have any fixings at the back; I might nick that idea unless the previous owner has any going spare :mrgreen:
Post by Corky » Sun Apr 22, 2018 8:54 pm
Probably not, they were a PITA to make :lol:
