LRP 335E Sprint Coupe
Dcrosby13
Has thanked: 34 times
Been thanked: 103 times
Post by Dcrosby13 » Thu Apr 04, 2019 8:26 pm
Thanks, is the box your using from the Mustang?
I break stuff...... :w
Has thanked: 158 times
Been thanked: 1088 times
Post by scimjim » Thu Apr 04, 2019 8:29 pm
The plastic covers can be painted?
turbster
Has thanked: 66 times
Been thanked: 56 times
Post by turbster » Thu Apr 04, 2019 8:41 pm
That’s the cover I want, Focus one would look rubbish..
As the Mustang boxes are over £2k second hand, I shall be trying a MX5 6 speed which shares the bolt pattern
LRP 335E SE4a
XRF 976H SE5
www.gtevolution.co.uk
Dcrosby13
Post by Dcrosby13 » Thu Apr 04, 2019 9:08 pm
Interesting 😎
Has thanked: 339 times
Been thanked: 162 times
Post by MikeyBikey » Sat Apr 06, 2019 8:43 pm
Mx5 or rx8. If rx8 I understand the 5 speed is the better box. ?
Post by scimjim » Sat Apr 06, 2019 9:01 pm
I think the Mx5 6 speed is the same as the RX8 box - Aisin AZ6 (is200, s15, gt86/brz)?
Depending on engine torque, diff ratio and wheel/tyre sizes, some people use the 6 speed as a 5 speed box and ignore first gear.
Post by MikeyBikey » Sun Apr 07, 2019 6:14 pm
Hmm that seems a good idea, giving you a longer 'first use' gear ?
fightingtorque
Post by fightingtorque » Sun Apr 07, 2019 6:44 pm
Yes, it's basically the same but the front casting is different. I have an MX5 6 speed gearbox in mine.
The MX5 has the starter motor on the left, the RX8 has it on the right, if you are standing at the front of the car and looking at it.
Also, the MX5 gearbox has a speed sensor, which is electronic in the 6 speed but the mechanical one from the 5 speed fits. People tell me the RX8 gearbox does not have a speed sensor at all.
turbster
Post by turbster » Mon Apr 08, 2019 9:25 am
Sorry for the late reply, I’m not getting notifications anymore!?
My descision to go with the 6 speed rather than the 5 is based on the final drive used in the MX5, the 5 speed car uses a 4.1 and the 6 uses a 3.7 which is closest to the ratio in the Coupe.. If it’s wrong I’ll swap it, or fit the T5 I have sat on the shelf :wink:
LRP 335E SE4a
XRF 976H SE5
turbster
Post by turbster » Tue Apr 09, 2019 9:32 pm
The gearbox arrived today, bolts up as it should and the gear lever couldn’t be better placed! All good so far 8)
LRP 335E SE4a
XRF 976H SE5
Has thanked: 215 times
Been thanked: 116 times
Post by efi_sprintgte » Tue Apr 09, 2019 9:45 pm
8)
Post by MikeyBikey » Tue Apr 09, 2019 9:55 pm
looks great. Last year I also bought a rx8 5 speed and adaptor plate to put behind the essex but the omega 3.2 made that redundant !
turbster
Post by turbster » Tue Apr 09, 2019 10:53 pm
I’m sure you’re not too concerned about that now!!
I’m putting an RX8 box in my road GTE, so I’ll find out all about that then..
LRP 335E SE4a
XRF 976H SE5
turbster
Post by turbster » Wed Apr 10, 2019 7:32 am
Fly by wire in a Scimitar, whatever next!!??
LRP 335E SE4a
XRF 976H SE5
turbster
Post by turbster » Mon May 06, 2019 10:29 pm
So as I wait for the ECU and harness, I have to find a home for the intercooler.. I want to get it in a good position without ruining the front of the car! After some welcome advice from CNH, I’ve decided to open up the current number plate recess and make a short section of ducting opening up to the intercooler. It’s actually the Ecoboost Mustang intercooler and the inlet and outlet drop nicely each side of the chassis legs!
LRP 335E SE4a
XRF 976H SE5
