Megan3
Been thanked: 842 times
Megan3
Post by scimjim » Mon Jun 11, 2012 8:57 pm
As some of you may know, scimrick and I came to an arrangement where he had my GTC and I had his lop-sided SS1 and a garage full of spares :D both cars were T&T but the SS1 had a cracked (and previously repaired crack) chassis and the GTC needed lots of TLC (and embarrassingly has developed a running fault :twisted:)
So, on Friday 1 June (Saturday was Andy's 18th birthday), I collected Andy from school in Suffolk in GavinR's trusty Transit with GTC on the trailer and set off for the centre of Norwich. Richard and Mrs P were great hosts (coffee AND cake :D) and we quickly had the cars swapped and van loaded for the trip home.
scimrick
Re: Megan
Post by scimrick » Mon Jun 11, 2012 9:15 pm
Hi Jim,
well done, glad to see Megan has a good home.
Will catch up later with you, off to borrow a spare distributor now for checking tomorrow!
Richard
scimrick
Re: Megan
Post by scimrick » Mon Jun 11, 2012 11:25 pm
Ah Megan, what a Mistress
Had me entranced,
Demanded attention,
Required presents,
Needed loving,
Had a separate residence,
Took me away from my wife,
Drank only the most expensive liquids,
Was an excuse for expensive weekends away,
Then left me for another (and younger!) man
sob, sob says Scimrick...............when will I learn about Scimitars!!!
Re: Megan
Post by scimjim » Mon Jun 11, 2012 11:32 pm
But you'll soon fall in love with her more experienced and voluptuous older sister - she's faster and sexier when she's not sulking :mrgreen:
Re: Megan
Post by scimjim » Sun Jun 17, 2012 9:10 am
Gearbox decided to die so Andy managed to get home this weekend (sports day cancelled due to rain :D ) and we ripped the engine & box out and fitted the gearbox from G97.
Also swapped the leaky exhaust manifold (perfect replacement included in deal) and tried (unsuccessfully) to find the electrical problem with lights and lighter. Several connectors to the front lights needed replacing and we now have working reverse lights again :mrgreen:
Re: Megan
Post by scimjim » Mon Jun 18, 2012 3:33 pm
After the gearbox change, the car refused to start :evil:
A quick check showed no spark (anywhere) and a wiggle whilst turning the engine over confirmed it was the plug to the ignition module thingy mounted on the dizzy. Stripped the loom and found a brittle wire with cracked insulation, so a replacement plug was found and fitted - car started straight away :D Andy got back to school in Suffolk without problems on Sunday (including a rest stop) and drove out to his girlfriends and back without problems - but it wouldn't start this afternoon (same symptoms - no spark) :twisted:
Wiggle test wont work, so an ignition module and diddy spanner will be dispatched post haste :roll:
Gemini Bob
Re: Megan
Post by Gemini Bob » Mon Jun 18, 2012 5:59 pm
Teething trouble Jim, all will be fine once it has done a few miles :wink:
Bob
HUE 1979 SE6a GTE Auto
If the cap fits wear it.
Scimitars Biggest Fan
Re: Megan
Post by scimjim » Mon Jun 18, 2012 9:46 pm
Another wiggle test worked, so new dizzy plug loom made up and will be posted tomorrow along with another module (in case it's the connections to the dizzy (but module seems to be on tight))
Re: Megan
Post by Roger Pennington » Mon Jun 18, 2012 9:57 pm
Did you use the conductive gunge on the joint when fitting it? or is that something that's not necessary in reality?
Has thanked: 191 times
Been thanked: 98 times
Re: Megan
Post by MikeyBikey » Mon Jun 18, 2012 10:02 pm
Sterling stuff Jim. :lol:
Re: Megan
Post by scimjim » Mon Jun 18, 2012 10:26 pm
Roger Pennington wrote:Did you use the conductive gunge on the joint when fitting it? or is that something that's not necessary in reality?
I didn't have any with me Roger but the stuff on there was slightly tacky still, so I wiped it around a bit.
speedy555
Re: Megan
Post by speedy555 » Mon Jun 18, 2012 11:01 pm
Makes me wonder why Im having to get worked up before a simple gearbox change! :)
Fantastic work!
Dave Speed
1970 se5
Prev. ss1 ti/68 coupe/77 & 78 6a / 7x 5a's / '85 SS1 /87 SS1 1.3/ 2x '81 6b's / Cipher / 69 se5 / rialto / Rochdale Olympic
http://www.facebook.com/ssgclassics
SCIMITAR PAINT & BODYWORK... Specialist fibreglass liquid coating technician
Re: Megan
Post by scimjim » Mon Jun 18, 2012 11:12 pm
It's nice to have decent facilities again (even if I haven't finished moving out of the old one yet!) - hope your new place is ok Dave?
Re: Megan
Post by Roger Pennington » Tue Jun 19, 2012 9:29 pm
Thanks Jim, the reason I asked is that I carry a spare module in the car on a "just in case needed" basis, but I don't currently have any spare conductive goo, so I was just wondering if I should put it on my shopping list? I presume somewhere like Maplins might do it?
Re: Megan
Post by scimjim » Tue Jun 19, 2012 9:40 pm
