G97 - zetec inside
Has thanked: 171 times
Been thanked: 158 times
G97 - zetec inside
Post by b.c.flat hat » Sun Mar 24, 2019 10:08 am
Chuffin' 'eck Jim.
I think yer car prefers yer 'ands on the spanners, not the steerin' wheel!
Has thanked: 155 times
Been thanked: 1052 times
G97 - zetec inside
Post by scimjim » Sun Mar 24, 2019 6:15 pm
Thanks to Phil who popped down today with his modified Megasquirt and laptop.
After much messing, we tested the Rev limiter :mrgreen:
I’ve asked Ian to look at the youtube problem - just click the link for now.
Edit - Ian has fixed it. Slightly different address format to what we previously used - press quote to see the code.
Has thanked: 295 times
Been thanked: 229 times
G97 - zetec inside
Post by Corky » Sun Mar 24, 2019 7:52 pm
Nice one! Looking forward to seeing the numbers.
Has thanked: 327 times
Been thanked: 157 times
G97 - zetec inside
Post by MikeyBikey » Sun Mar 24, 2019 8:00 pm
:D Does Phil live in your garage ?
He looks like you've disturbed him in his lair
G97 - zetec inside
Post by scimjim » Sun Mar 24, 2019 8:28 pm
Numbers won’t be high as this is a Mundano 1.8 as opposed to the 2.0 litre with I wrecked. Hopefully get some mapping done before the rolling road.
Has thanked: 78 times
Been thanked: 707 times
G97 - zetec inside
Post by philhoward » Sun Mar 24, 2019 9:28 pm
Feels like it at times :D
G97 - zetec inside
Post by scimjim » Wed May 01, 2019 10:07 pm
So after lots of setbacks, I finally got it to Northampton Motorsport rolling road for mapping and weighing. The standard 1800 should produce 115 BHP and this one made 120.9 with 126.4 lbft torque. With vernier pulleys I might have got a bit more but as the weight was up a little (858Kg without me as opposed to 846 last year) I have almost exactly the same handicap figure but more torque and the engine feels like it winds up quicker.
Has thanked: 194 times
Been thanked: 104 times
G97 - zetec inside
Post by efi_sprintgte » Wed May 01, 2019 10:48 pm
I think the real world gain will be massive as the twin carb CVH bogged a lot in places. Should be mega in the wet now!
Dads coupe has less power and lower peak rpm then black beast had but we can run a higher diff ratio due to the low down torque and wide power band so speed achievable in each gear isn’t affected.
Real world comparison was Prescott hairpin used to be clutch kicking in first, whereas we can pull clean in second with the stock BOB.
Has thanked: 428 times
Been thanked: 370 times
G97 - zetec inside
Post by CNHSS1 » Thu May 02, 2019 8:37 am
Great work Jim, as James says, I'm sure the combo of efi , decent mapping and a revvier motor will pay dividends in times with same handicap.
G97 - zetec inside
Post by philhoward » Thu May 02, 2019 9:40 am
scimjim wrote:
Sun Mar 17, 2019 9:17 pm
Spent almost all day checking the wiring and came to the conclusion that the injector drivers are toast. I have fuel pressure and can jury rig a supply to make the injectors fire, I have continuity from each injector wire back to the ECU and the tunerstudio says it’s trying to fire them - but still no fuel :(
Just as a post mortem on this aspect - not only were most of the injector circuit driver components toasted to oblivion, so was the driver chip which runs them as well as the track on the PCB that feeds it with a supply voltage in the first place. Advantage of an early Megasquirt is it’s all low value discrete components so several hours with a soldering iron and it was all replaced for the cost of a round of drinks :D
By the looks of it, it wasn’t the first time half of the bits had been replaced either..
Just annoying (to put it mildly) that a “working” unit (as bought) was absolutely goosed :evil: so a lot of time was wasted in the first place chasing shadows.
Very glad it held up for the whole of the session though.. :wink:
Has thanked: 36 times
Been thanked: 49 times
G97 - zetec inside
Post by nickkeyser » Thu May 02, 2019 12:51 pm
Awesome! glad its all come together now. Did Troy map it? he was great when we took mine up there.
This is going to be a great car on track - as JC says, the switch to EFI will make a massive difference; one of the very noticeable things after converting mine was the absence of any coughing and spluttering when you hoof it out of certain bends - it just picks up and goes.
SSSC Champion 2019
SS1 CVH 1600Ti
G97 - zetec inside
Post by MikeyBikey » Fri May 03, 2019 9:17 pm
Well done Jim and phil :) nice to see it finally there . Hope you have a mega ( :D ) season
Dcrosby13
Has thanked: 30 times
Been thanked: 89 times
G97 - zetec inside
Post by Dcrosby13 » Fri May 03, 2019 10:23 pm
Well done guys
I break stuff...... :w
G97 - zetec inside
Post by scimjim » Thu May 16, 2019 9:28 pm
I took G97 for its MOT last week (which it passed) but it threw up a problem with the throttle position pickup. Turned out to be a broken wire, so we rewired it along with a new 37 pin plug on the Megasquirt and a couple of inline plugs on the loom to make any future trouble shooting a bit easier.
G97 - zetec inside
Post by scimjim » Sat Jun 22, 2019 4:28 pm
Sorry nick, I missed this - yes it was Troy, he was great once he refreshed his rusty Megasquirt memory :D
First 2 events of the season were Prescott and Harewood (having missed Gurston and Wiscombe so totally re-organised calendar) and the car was great - 2 seconds up on last years Prescott times and 4 seconds up at Harewood. Next is Castle Combe in July which doesn’t really suit the car (but we have to do at least one circuit amongst the hills, so this is closest). Also going to Shelsey this year which I’ve wanted to drive for years but never got round to. Another Harewood after Curbs and a late Combe will just be the 8 events I need.
