G97 - zetec inside
Dcrosby13
Has thanked: 34 times
Been thanked: 103 times
G97 - zetec inside
Post by Dcrosby13 » Thu Mar 14, 2019 8:43 pm
I'd be happy just to be a passenger 😁
I break stuff...... :w
Has thanked: 158 times
Been thanked: 1093 times
G97 - zetec inside
Post by scimjim » Fri Mar 15, 2019 10:34 pm
I took two days off work to get Bens Sabre out of stairage yesterday and help a friend take his project Herald into town for paint today - which meant I got two extra half days on G97 :D
scimjim wrote:
Thu Mar 14, 2019 8:34 pm
New list to make test day looks like this
Plumb in remote oil filter
Finish plumbing in cooling system (8mm breather pipe)
Fit fuel rail (needs new o-rings)
Fit inlet manifold (waiting for fuel rail o-rings)
Fit alternator tensioner bracket
Fill engine with oil
Fit crossbeam and protec dampers (modify to 1/2” bolts)
Sort Megasquirt map
Refit drivers door card
Refit bonnet
Refit bootlid
Missed off replace accelerator pedal that I bodged last season (did today) and fit new cable (also done).
Fitted the dampers, remote oil filter and finished off the coolant hoses. Hopefully the o-rings that Phil has will fit when he comes down to collect C686 tomorrow, and I can get G97 started.
Has thanked: 339 times
Been thanked: 162 times
G97 - zetec inside
Post by MikeyBikey » Sat Mar 16, 2019 9:43 am
Great stuff Jim.
G97 - zetec inside
Post by scimjim » Sat Mar 16, 2019 8:46 pm
Another few hours today with Phil’s help after we’d moved everything out to get C686 out and put them all back.
Unfortunately we have a lack of fuel and a sluggish starter, so still plenty of work to do tomorrow if it’s going to make test day.
Has thanked: 216 times
Been thanked: 116 times
G97 - zetec inside
Post by efi_sprintgte » Sun Mar 17, 2019 6:55 am
Good luck Jim
G97 - zetec inside
Post by scimjim » Sun Mar 17, 2019 9:17 pm
So it’s back in one piece and I fitted the alternator tensioner - but it still won’t start.
Spent almost all day checking the wiring and came to the conclusion that the injector drivers are toast. I have fuel pressure and can jury rig a supply to make the injectors fire, I have continuity from each injector wire back to the ECU and the tunerstudio says it’s trying to fire them - but still no fuel :(
G97 - zetec inside
Post by efi_sprintgte » Sun Mar 17, 2019 10:10 pm
What’s the voltage at the CPS?
Edit - whilst cranking I mean
Has thanked: 309 times
Been thanked: 233 times
G97 - zetec inside
Post by Corky » Sun Mar 17, 2019 10:14 pm
Nightmare!
Good luck getting it sorted.
G97 - zetec inside
Post by scimjim » Sun Mar 17, 2019 10:30 pm
cant remember if I checked it while cranking but full battery voltage with ignition on. What would low/no voltage during cranking indicate other than driver failure?
Has thanked: 86 times
Been thanked: 733 times
G97 - zetec inside
Post by philhoward » Mon Mar 18, 2019 12:37 am
It’s running EDIS for sparks and was sparking successfully on Saturday and I could see a stable reading for RPM and injector PW so confident it isn’t suffering resets from low voltage.
G97 - zetec inside
Post by efi_sprintgte » Mon Mar 18, 2019 6:17 am
Cool, I’ve been caught out before.
G97 - zetec inside
Post by scimjim » Sat Mar 23, 2019 5:35 pm
So we tried another Megasquirt and got it started - proving that mine has a problem. Unfortunately we had an oil problem which I didn’t notice until it had 30 seconds at 3000rpm - turned it off but the bottom end had siezed :(
I found a 1.8 engine recently removed from a mondeo - which luckily was on my route back from a meeting on Wednesday, so this happened:
Dcrosby13
G97 - zetec inside
Post by Dcrosby13 » Sat Mar 23, 2019 5:51 pm
Glad you got it sorted, are you stripping it before use or giving it a go as it is?
G97 - zetec inside
Post by philhoward » Sat Mar 23, 2019 5:52 pm
Too late - that’s the replacement already in! Internals looked very clean so winging it.
G97 - zetec inside
Post by MikeyBikey » Sun Mar 24, 2019 9:09 am
Blimey, bad luck mate. Keep at it.
