G97 - zetec inside
Dcrosby13
Has thanked: 30 times
Been thanked: 89 times
DJs SS1 - now dad's sprint car
Post by Dcrosby13 » Fri Mar 08, 2019 9:52 pm
Looking good
I break stuff...... :w
Has thanked: 155 times
Been thanked: 1052 times
Post by scimjim » Fri Mar 08, 2019 9:58 pm
Except I have a load left to do and no time to do it :D
Dcrosby13
Post by Dcrosby13 » Sat Mar 09, 2019 8:57 am
At least you have an engine, we only have bits of one 🤣
AndyM
Post by AndyM » Sat Mar 09, 2019 11:39 am
Jim, what are the battery connectors called you have used in the photo on the previous page? I’ve seen them on yours and on Nicks last year. I need some for my van leisure battery and can’t find what they are called or where to get them from?
Thanks Andy
Has thanked: 78 times
Been thanked: 707 times
Post by philhoward » Sat Mar 09, 2019 11:42 am
Anderson connectors.
Post by scimjim » Sat Mar 09, 2019 1:54 pm
:D sorry - on a train to twickenham :D
AndyM
Post by AndyM » Sat Mar 09, 2019 9:02 pm
Thanks Phil,
Post by scimjim » Sun Mar 10, 2019 8:43 pm
Late start after a great game in Twickenham yesterday :P
Spent some time looking at the other remote oil filter housing Phil found - unfortunately it was going to take too much time and effort to fit, so it all went back together again :D
Then I mocked up the cooling system - just need a couple of tee pieces and it’ll be final fit.
Finally, I connected up the electrics under the bonnet and with a lot of help from Phil, tidied up the interior wiring (earths and live feeds mainly).
Came out to find it had snowed! :D
So - jobs left to do
Fit swirl pot
Fit HP pump
Sort fuel pump(s) wiring
Plumb in remote oil filter (waiting for pipe)
Plumb in cooling system (waiting for a couple of tee-pieces)
Fit fuel rail (needs new o-rings)
Fit inlet manifold (waiting for gasket)
Fit alternator tensioner bracket
Fit alternator/water pump belt (ordered)
Possibly fit lambda bung
Fill gearbox with oil
Fit gearbox mount
Connect speedo cable
Fill engine with oil
Fit crossbeam and protec dampers (modify to 1/2” bolts)
Sort Megasquirt map
Refit drivers door card
Refit bonnet
Refit bootlid
MOT
Has thanked: 295 times
Been thanked: 229 times
Post by Corky » Sun Mar 10, 2019 9:53 pm
Wow this is really coming along 8)
Post by scimjim » Sun Mar 10, 2019 10:58 pm
Not as fast as I’d like Steve - if I’m lucky we’ll be live mapping at Curborough :P
Post by scimjim » Mon Mar 11, 2019 9:16 pm
Grabbed a few hours today and filled the gearbox with oil, bolted up the mount, speedo cable, welded in a lambda boss and fitted the exhaust. Dropped it off axle stands and removed the fuel tank with the intent of fitting a different one - but with the lack of time, I think I’ll put it all back in with the HP pump and swirl pot as planned.
G97 - zetec inside
Post by scimjim » Thu Mar 14, 2019 8:34 pm
New list to make test day looks like this
Finish plumbing in cooling system (8mm breather pipe)
Fit inlet manifold (waiting for fuel rail o-rings)
Sort Megasquirt map
Refit bonnet
Refit bootlid
Dcrosby13
G97 - zetec inside
Post by Dcrosby13 » Thu Mar 14, 2019 8:36 pm
I'm looking forward to seeing this on Tuesday, could I hitch a ride around the track?
G97 - zetec inside
Post by philhoward » Thu Mar 14, 2019 8:37 pm
Have oil hose packed, selection of O rings and laptop.
I’ve got several feet of 8mm hose which is fake R6 but should be fine for water?
Saturday OK?
G97 - zetec inside
Post by scimjim » Thu Mar 14, 2019 8:40 pm
8mm hose arrived today, as did 13mm oil pipe. I’ll have a better root around for o-rings tomorrow as I’d like to hear it run as soon as poss :D
Daryl, if I make it you’ll be welcome to take it for a spin :D
