G97 - zetec inside
Has thanked: 77 times
Been thanked: 706 times
DJs SS1 - now dad's sprint car
Post by philhoward » Sun Jan 06, 2019 9:26 am
scimjim wrote:
Mon Dec 31, 2018 7:49 pm
This is the eurospeed item that seems to be discontinued. Looking closely, I think it might use two of the engine mount holes anyway?
In fact, I’m not even sure that’s a silvertop?
Nope - that’s a Duratec.
Has thanked: 101 times
Been thanked: 153 times
Post by reliant-reviver » Sun Jan 06, 2019 2:08 pm
scimjim wrote:
Sun Jan 06, 2019 9:17 am
I might have exhaust clearance problems?
Just don't turn left! Simple.
More pics of the alternator and water pump arrangement, doesn't look like there's much space for anything!
Has thanked: 154 times
Been thanked: 1051 times
Post by scimjim » Sun Jan 06, 2019 4:45 pm
Starter motor
Post by scimjim » Sun Jan 06, 2019 7:34 pm
Modified the CVH sandwich plate (between block and gearbox) to fit the zetec
Post by scimjim » Sat Jan 26, 2019 8:07 pm
Got the gearbox (with the modified spacer) and starter motor fitted today.
and the Megasquirt, fuse box and relays fitted in the passenger footwell
the battery and cutoff switch are already on the other side
Then I modified the remote oil filter sandwich plate for a little more clearance.
With the mount spaced away from the block it now passes the fag paper test :D
Post by scimjim » Sun Jan 27, 2019 9:35 pm
took it all apart again today :D
After lots of careful measuring, I thought that the nice alloy sump would slightly foul the crossmember. option 1 was to remove the crossmember (as per K series Sabre), option 2 was to remove some of the sump :shock:
I was right, loads of room at the front
and now about 10mm at the rear (not as close as it looks :))
and the remote filter clears the steering column (also not as close as it looks).
Alternator to look at next weekend :D
Has thanked: 428 times
Been thanked: 367 times
Post by CNHSS1 » Sun Jan 27, 2019 11:08 pm
Liking the progress mate, so long as things miss, doesnt matter if a millimetre or a mile 8)
Post by scimjim » Sun Jan 27, 2019 11:40 pm
I'm using your ethos of grind it away till it fits - if I take too much off I need to buy a TIG welder :D
Post by scimjim » Sun Feb 03, 2019 11:22 pm
Lots more clearance issues to solve - the exhaust hit the heater motor. 2 options, remove the heater motor or modify it. It already has an unknown motor grafted into a Reliant casing, so fitting something with a smaller fan (and lighter) was easy enough, then chop a section out of the casing and weld up (pics to follow).
The alternator needed a notch taking out of the engine mount (which needs some strength adding back later) and it’s still close with the water pump outlet and the expansion tank lower pipe.
Then the oil filter housing again. I didn’t like the spacers on the RH engine mount, so I cut a lot more alloy off the filter housing, a bit off the engine mount - and eventually it all fitted. Mounted the EDIS unit on a chunk of alloy as a heatsink (where the coil normally goes in the pic below) and dropped the inlet on loosely - now the final check next weekend is bonnet clearance.
Post by philhoward » Mon Feb 04, 2019 3:00 am
This would be a bad time to mention I think I’ve found (whilst looking for something else completely) a possible adaptor to move the oil filter away from the block... :oops:
Been thanked: 62 times
Post by Nick » Mon Feb 04, 2019 9:18 am
Jim,
I think a Zetec is a great conversion, but does it risk putting you in Libre .?
Post by scimjim » Mon Feb 04, 2019 9:52 am
Jim,
RG specialist production Nick.
11.1.2. Road-Going Specialist Production Cars – Cars with a minimum annual production of 20 Chassis which do not qualify as Road-Going Series Production Cars. (Saloons and Sports Cars produced in quantities of not less than 1000 per annum.)
11.5.2. For Road-Going Specialist Production Cars, the cylinder block and head must be of a make and type produced in at least 1,000 identical units originally available through the normal commercial channels of a land vehicle manufacturer.
Post by Nick » Mon Feb 04, 2019 12:15 pm
Jim,
That makes sense, I know there is some controversy over standard versus specialist, but no doubt best addressed on an individual basis.
Post by scimjim » Sun Mar 03, 2019 9:12 pm
Checked that the bonnet fits then spent most of the day finishing the LH Engine/alternator mount - but didn’t take any photos :D
Also finished off the heater motor - slightly smaller motor and fan from some random Japanese car.
Post by scimjim » Fri Mar 08, 2019 9:47 pm
Engine re-assembled and dropped back in (hopefully for the last time) today.
Then Andy arrived with the alternative oil filter mount :D
