G97 - zetec inside
Been thanked: 876 times
DJs SS1 - now dad's sprint car
Post by scimjim » Wed May 16, 2018 6:56 pm
Measured the required length at 600mm, so I ordered the 750mm cable - £15 with VAT & postage.
I need to sort the throttle stop, replace the interior kill switch (somehow managed to snap the handle at Gurston :? ) and charge the go-pro and remote before Prescott.
Post by scimjim » Fri Dec 28, 2018 4:55 pm
So, third place was most unexpected this year and plans are afoot for a bit more power next year.
This happened before Christmas
And this happened today :D
Post by scimjim » Fri Dec 28, 2018 7:17 pm
So that’s the mock-up engine that Phil had in KAB. Decompression plate and turbo fitted so I need to remove the plate and the turbo oil feed, as well as blanking off the turbo oil return boss in the sump.
It has a new clutch fitted, the correct Sierra starter and the correct alloy sump to clear the SS1 lower crossmember.
It’s a 2 litre block with ARP bolts and a Rover inlet TIG welded to the 1800 head, then the ends cut off the plenum and welded on the opposite side, to give a forward facing throttle body.
CCT133 clutch release bearing ordered as well as a Zetec to CVH exhaust manifold adaptor plate (minimum hassle and I get to keep the free flow exhaust that’s fitted already). Probably going with Megasquirt.
Dcrosby13
Post by Dcrosby13 » Fri Dec 28, 2018 8:29 pm
Ooh going turbo?
I break stuff...... :w
Post by scimjim » Fri Dec 28, 2018 8:59 pm
Nope - if I wanted a turbo I’d probably fit a Ti or DET :D
I’d love to supercharge a CVH but just don’t have the time to develop it at the moment.
Dcrosby13
Post by Dcrosby13 » Fri Dec 28, 2018 9:00 pm
True, how much power are you hoping for?
Has thanked: 77 times
Been thanked: 119 times
Post by reliant-reviver » Fri Dec 28, 2018 9:01 pm
Ooooh like where this is going. Does this mean KAB will be being rightfully returned to CVH power (although I recall the original engine was thieved)
Post by scimjim » Fri Dec 28, 2018 9:47 pm
Probably/possibly :D
Been thanked: 551 times
Post by philhoward » Fri Dec 28, 2018 9:54 pm
That’s the plan this week.. :D and yes, the original was indeed thieved.
Funnily enough one of the possible engines makes a very sneaky guest appearance in the photo but stands a chance of being close to original (1600 and carb) of which that one is neither.
Luckily I still have the pushmepullyou dizzy and made-specifically exhaust manifold.
Post by reliant-reviver » Sat Dec 29, 2018 9:39 am
The adapted Dellorto dhla40 esprit turbo carb I have is spare now if you want to keep it carburated
Post by philhoward » Sat Dec 29, 2018 9:48 am
I’ve got an Alfasud turbo DRLA carb (as used on Big Bob so downdraught) sitting in a box which I only found still existed after a Zetec had found its way into the mix.
Has thanked: 85 times
Been thanked: 59 times
Post by efi_sprintgte » Sat Dec 29, 2018 4:05 pm
If I was doing a small capacity carb’d turbo build I would use a SU carb as fitted to MG metro/maestro/montego.
Post by philhoward » Sat Dec 29, 2018 4:44 pm
Still got one of those..in fact, the last time KAB was (nearly) on the toad it was running an SU!
Has thanked: 208 times
Been thanked: 102 times
Post by MikeyBikey » Sat Dec 29, 2018 5:00 pm
I worked for jag in the 80s and turbo maestros / Montegos were brilliantly quick but I thought they were EFI.
Post by philhoward » Sat Dec 29, 2018 5:27 pm
Nope - still ran an SU carb. Montego and Maestro had an electronic idle and choke system so I adjusted a Metro one as they have a manual choke..
