DJs SS1 - now dad's sprint car
Been thanked: 854 times
Re: DJs SS1 - now dad's sprint car
Post by scimjim » Tue Apr 05, 2016 8:53 am
poly all round which is why I wasn't bothered about tightening it up in the air.
Post by scimjim » Sat Apr 09, 2016 11:14 am
So the test day was a huge success as far as I was concerned. G97 made it there, didn't break down or leak during the event and I managed 15 or 16 laps, tried both sets of wheels & tyres, changed the quick-shift gearstick back to standard, adjusted dampers to compensate for snap oversteer and played around with the fuel system to try and overcome the DCNF LH corner float problem.
So, additional jobs over the pre MOT and pre first event jobs are:
Buy and fit new 13" tyres (R888R are looking favourite)
Change carbs - DMTR, bike carbs or injection?
Change front springs - needs to be an inch or so lower.
Build and fit 3.92 LSD.
Has thanked: 75 times
Been thanked: 118 times
Post by reliant-reviver » Sat Apr 09, 2016 11:26 am
What happened to the low 350s from Nick Halls old sprinter that Jake put on that red SST and AJL took off?
Possibly too stiff and too low though
Post by scimjim » Sat Apr 09, 2016 11:28 am
Far too low and stiff after Jake lopped off a coil or two :shock:
Post by reliant-reviver » Sat Apr 09, 2016 11:38 am
Oh he did that too?!
Been thanked: 213 times
Post by AJL Electronics » Sat Apr 09, 2016 12:04 pm
No the ones I took off are here.
Been thanked: 26 times
Post by nickkeyser » Sat Apr 09, 2016 1:02 pm
We never really had issues with the DCNFs until I fitted the slicks, and even then it only suffered on the lefthander onto the straight going the wrong way, and only at curborough - I found changing the line through the bend helped a bit. Although it was probably suffering a bit everywhere.
When I looked there are some mods you can do to improve it.
Defo injection if not DCNFs. What fuel pressure are you running? Can't remember off the top of my head if it was flooding or starvation.
Post by AJL Electronics » Sat Apr 09, 2016 1:15 pm
The ends of the short springs are painted black, so it doesn't appear that they have been cut.
Post by scimjim » Sat Apr 09, 2016 1:32 pm
Brand new Facet posi-flow failed just before the test day so I fitted an unknown Facet cylindrical pump. Although it would only cough on the first long left and hesitate coming out of the molehill, it would lose all power coming onto the straight uphill, so it may well be slightly low fuel pressure - I'll get a regulator and gauge on it before totally condemning them. I recall some mods were available but can't find anything online? Pretty sure I have everything for injection and I planned to go megajolt anyway - perhaps megasquirt is the way ahead (means I'll have to buy another one for 8 Ball though!)
Post by scimjim » Sat Apr 09, 2016 1:33 pm
AJL Electronics wrote:The ends of the short springs are painted black, so it doesn't appear that they have been cut.
IIRC they gave about 3" ground clearance? Don't think Nicks car was that low, so I assumed they'd been cut?
Post by reliant-reviver » Sat Apr 09, 2016 2:15 pm
They are very short (8.8" rings a bell ) and require supporting mods to actually work. Might suit your racer though.
Still Have My identical pair to go back on VTO when the time comes
Post by scimjim » Sat Apr 09, 2016 2:20 pm
Actually they may not have had seating rubbers on?
Has thanked: 264 times
Been thanked: 228 times
Post by CNHSS1 » Sat Apr 09, 2016 3:15 pm
Ti is heavier at front anyway. If still too low add 2nd pair of rubber NVH rings above std ones in sprin turret
Post by AJL Electronics » Sat Apr 09, 2016 4:08 pm
scimjim wrote:Actually they may not have had seating rubbers on?
That's right, no seats were fitted.
Post by scimjim » Sat Apr 09, 2016 4:32 pm
May pop in tomorrow morning? :-)
