The Beige Se5a : rebuild becomes Omega conversion
DarrylWebb
Has thanked: 70 times
Post by DarrylWebb » Sat Dec 30, 2017 5:58 pm
Thanks, Hugh. There's nothing to suggest it's worth doing the oil seal while in there. I think I just got unlucky.
Any photos I've found online of the thrust spacer don't show a groove. I have the local Vauxhall breaker checking his stock, as a new one is £50!!!
New crank pulley bolt ordered too.
Incidentally, I found Omega 'micro-fiche' diagrams, which might be a useful resource for others.
https://vauxhall.7zap.com/de/car/v94/e/5/
superleggo
Post by superleggo » Sun Dec 31, 2017 10:50 am
Thanks for posting the Micro-fiche link.
Post by Roger Pennington » Sun Dec 31, 2017 5:25 pm
That looks like a useful link, Darryl, so I've copied it to the Omega conversion "How To" sticky
DarrylWebb
Post by DarrylWebb » Sun Jan 14, 2018 4:23 pm
Having hunted the internet for the thrust washer, GM part number 90298202 is etched in my brain.
I had to go with a new one at just shy of £50 (Autovaux were the cheapest). At least it came without the grooved mark I had on the original.
Oil seal and thrust washer fitted, crank pulley torqued up, timing belt fitted and timed today. I'll leave it a few days to double-check I got the timing right. After that building up the front of the engine should be simple enough.
DarrylWebb
Post by DarrylWebb » Sat Jan 27, 2018 11:43 am
There were no dramas getting the front of the engine built again, so it lives once more. A video if you can wait on OneDrive calling it up :
https://1drv.ms/v/s!AmY2jNmNfs0ZiiYpSqkTGyF-H_Do
superleggo
Post by superleggo » Sat Jan 27, 2018 9:06 pm
Top work. Looks and sounds great. I am very envious.
