Gear Stick
rjudcsx
Has thanked: 15 times
Gear Stick
Post by rjudcsx » Fri Mar 06, 2020 9:54 am
Hello everyone , new to this forum , purchased a 5a a few weeks ago [1974 man/od SUL 139N] and as mentioned in my Introduction Post the delivery driver somehow snapped the gear stick 1inch from its base . I have spoken to a few people and what I predicted to be an easy search for a Ford part [3000 Capri ,Granada ect ] has now become a little more complex as I have been informed that the stick is a Reliant one specific to this application. A picture can be seen in the Autobooks workshop manual page 67 "later type gearbox". Can anyone confirm that no other stick will fit but a Reliant one ,and if so, does any one have a second hand one in the shed that I might buy ? Thankyou all for your help, Richard J .
scimmy_man
Been thanked: 43 times
Gear Stick
Post by scimmy_man » Fri Mar 06, 2020 9:59 am
its a common problem,
most people sleve and weld it.
Has thanked: 166 times
Been thanked: 1160 times
Gear Stick
Post by scimjim » Fri Mar 06, 2020 11:04 am
It’s not Reliant specific at all (don’t believe everything you read on Facebook :D ) the only time I snapped one (on the brake rollers during MOT!) I found a spare in a scrapyard on a Capri (that was 1992 though :D )
Still quite rare unfortunately.
Has thanked: 73 times
Been thanked: 102 times
Gear Stick
Post by Oldconn » Fri Mar 06, 2020 1:29 pm
There was one for sale on the Facebook group Scimitar Parts a fgew days ago.
Has thanked: 64 times
Been thanked: 196 times
Gear Stick
Post by gtcse8 » Fri Mar 06, 2020 1:36 pm
Where are you?
I have a spare used one.
And I think I still have a complete unit with the base ( but will have to look).
rjudcsx
Gear Stick
Post by rjudcsx » Fri Mar 06, 2020 1:59 pm
Hello ,I live in Chapel St Leonards Nr Skegness Lincs [some one has to ]. I would be intrested in the part ,any chance of a picture so that I can compare ? Thankyou for your response .Richard J.
Geraint SabreGTCse5
Been thanked: 64 times
Gear Stick
Post by Geraint SabreGTCse5 » Fri Mar 06, 2020 3:45 pm
that was for an early 5 gearbox and I gather it is a remote one that is needed
Richard, two threads have morphed on this topic, as i mentioned on the other thread I have one, I know GW had some they bought them from me I suppose they may have sold them. If Mark can't locate his, I will locate one of my spares.
Geraint
rjudcsx
Gear Stick
Post by rjudcsx » Sun Mar 08, 2020 10:25 pm
Good Evening every one, thank you all those who have offered to look for a spare 5a remote gear stick to replace my broken one ,I look forward to a possible solution being found. In the meantime I need to consider a back up plan; as mentioned in a previous members post some have been sleeved and welded. Can the stick be extracted on its own ,avoiding the process of removing the whole remote unit [ levers,shaft,selector rods ect ] if so, could any one give a bit of an overview ? I am also a little concerned that the break in the shaft is directly in line with the top housing ,once welded could I find that my lateral gear stick movement is restricted to the point of being unable to select a gear [particularly reverse]. Its been a long weekend at my part time job supporting special needs adults, my ability to conceptualize this problem is some what impared [a bit like my spelling !] Thank you Richard .
Gear Stick
Post by scimjim » Sun Mar 08, 2020 10:43 pm
To get to the gearstick securing pin requires two people. you need to remove the centre console and the 3 nuts/bolts that hold the alloy base down (there’s then enough slack to lift the whole lot clear of the transmission tunnel). Unfortunately that means getting underneath to hold the nuts and more importantly, re-align the overdrive inhibit switch when you put it back together.
Gear Stick
Post by gtcse8 » Mon Mar 09, 2020 8:11 am
Here is my spare lever.
Never actually seen a broken one so don`t know where the weak spot is and weather they can be welded on the car.
rjudcsx
Gear Stick
Post by rjudcsx » Mon Mar 09, 2020 9:09 am
Morning Mark ,that's the one. I was told two " theories " why they snap .1 It is a deliberate flaw put into the lower part of the stick to ensure occupants are not impaled in the case of an accident ! 2 The incidents of breakage appear to peak during the winter [temp ?] However I am aware of how myths can become facts ;I had a" friend" who found the lost Bugatti 57 sc Atlantic once ! Back to reality , is the stick for sale and if so how much would you like ? Thankyou for all the effort you are putting into this issue . Richard .
Gear Stick
Post by gtcse8 » Mon Mar 09, 2020 9:16 am
Hi Richard
It cost me £25 when I bought it many years ago as a spare, bearing in mind its not been used for at least 10 years it should have a lot less wear than a used one off a current car.
Regards Mark
Gear Stick
Post by scimjim » Mon Mar 09, 2020 12:21 pm
Mine went at the pivot point (where the nylon bush sits) - there’s a sharp radius top and bottom and I think it was just a fatigue fracture after years of being forced sideways, forwards and backwards?
rjudcsx
Gear Stick
Post by rjudcsx » Mon Mar 09, 2020 7:47 pm
Mark ,PM sent from Richard Judson .
Geraint SabreGTCse5
Gear Stick
Post by Geraint SabreGTCse5 » Mon Mar 09, 2020 8:04 pm
I would suggest a good percentage of snapped gearsticks are due to drivers having difficulty in selecting gears due to wear in the linkage between the remote gearlever and the gearbox. Another sign of linkage wear is a widening of the alloy housing either side of the gearstick, again a result of a driver forcing the vehicle into gear.
Geraint
