Fuel line
Penfold13
Fuel line
Post by Penfold13 » Fri Apr 19, 2019 10:17 am
Hello,
Looking at getting fuel lines to replace the unknown stuff currently fitted, I know that AJL has the best stuff available, but which size and how much will I need? Any special clips/fitting to get at the same time? I was going to get some stainless steel hose clips whilst I was at it.
Thank you,
Chris
‘72 SE5A
Rev Light
Been thanked: 30 times
Fuel line
Post by Rev Light » Fri Apr 19, 2019 10:58 am
Andy will know. If in doubt, replace it all.
SE5a 'Fancier'
Has thanked: 117 times
Been thanked: 841 times
Fuel line
Post by philhoward » Fri Apr 19, 2019 11:04 am
Make sure they’re fuel line clips, not normal jubilee clips.
I’ve got a feeling it’s all 8mm? If using AJL’s Cohline then I think you need 12-14mm clips which I’m sure he sells as well?
I suspect 1m will do a full car, but as a Steve says, Andy will know for sure.
Rev Light
Fuel line
Post by Rev Light » Thu Apr 25, 2019 3:45 pm
Interestingly enough, I had a fuel line failure on my Campervan this weekend. All over the top of a flat four engine. Glad I spotted it before the engine got hot.
SE5a 'Fancier'
