Is a 5A improved over a 5 ?
Rust hater
Post by Rust hater » Sun Nov 25, 2018 6:59 pm
I'm fairly new to researching the Scimitar range and am leaning towards searching out a 5, but there seem to me many more 5As out there.
Is it a better car? The only differences I had become aware of were reversing lights, dashboard (to me the earlier looks nicer) and suspension trunnions. This website also says: "Chassis upgrades and a restyled interior, heater and rear lights led to the SE5a in 1972".
Is there much to choose between them? Was the chassis really 'upgraded' or just changed? Were the revised trunnions any better and if so, is it a simple job to fit later items to a 5? Did the 5A retain the same seats (to me the buttoned seats in the 6 series don't look so good). I'm not sure why a manufacturer would redesign a new model (if it was called such) with few changes.
Is the revised heater much better? I've picked up that heating/ventilation is not a Scimitar strong point.
If the 5A is a better car I may not concentrate so much on finding a nice 5
Any advice much appreciated.
rebel alliance
Been thanked: 62 times
Post by rebel alliance » Sun Nov 25, 2018 7:21 pm
Very slightly more powerfull engine in a 5a and the dash on a 5a is a bit fragile but it may come down to whats available within your budget...Buy the best you can projects can take a lot longer then you think 😊
Has thanked: 146 times
Been thanked: 1026 times
Post by scimjim » Sun Nov 25, 2018 7:23 pm
The trunnions weren’t changed AFAIK?
The heater/vent system is totally different, the 5a has footwell mounted motors and fresh air vents as well as an inlet at the base of the screen - the 5 has an older fashioned single motor mounted on the matrix. “Better” is a very subjective term :D
Seats are slightly different but nothing like the 6 series.
Personally the SE5 dash swings it for me (and I have one of each :D )
The lower wishbone mounts were changed in 73 (easy to retrofit), the overdrive box was changed in 73 (earlier has a nicer feel), the engine was updated in 72 (early 5a - can be retro-fitted to earlier cars).
*JP*
Has thanked: 15 times
Post by *JP* » Sun Nov 25, 2018 7:36 pm
Taken as a whole the differences are not that significant,which means that it's best to concentrate on getting the best example you can find for whatever you want to spend,that's what I would do.
roymck
Been thanked: 24 times
Post by roymck » Sun Nov 25, 2018 7:37 pm
The upper wishbones are different on later cars , they angled the ballpoint at a more optimum operating range they say to increase travel . Also thicker sub axles came later .
Agreed with Jim the dash and trim is nicer on a 5 and the switches better quality and just easier to source
ScimiTom
Post by ScimiTom » Sun Nov 25, 2018 8:21 pm
I adore my 5a, but I'd agree that the 5 is generally a bit nicer cosmetically - the dash and its toggle switches, especially. There are a couple of other external things, which you may have noticed - the thin (chrome?) side strip which gives more definition to the body, the '3 litres' badge (instead of the Scimitar logo), and (I believe, though I may be wrong) slightly more of a downwards 'dip' at the front end of the wings. Added to that, there is the rarity factor (far fewer 5s, and they are the true 'original' GTE). However, as others have said, if you see one for the right price, I wouldn't fuss too much over whether it's the 5 or 5a variant.
Tom
Current: 'Boffin' (1971 SE5a)
Has thanked: 160 times
Been thanked: 543 times
Post by Roger Pennington » Mon Nov 26, 2018 9:04 pm
The thin metal side strips (which came from the Herald estate, I believe) were only used during one year of production, so it isn't actually a general characteristic of all Se5s :)
Rev Light
Been thanked: 30 times
Post by Rev Light » Mon Nov 26, 2018 10:06 pm
I fall into the category of being a 5a owner that really would have preferred a 5 if I could have found one at the time. And like many here have stated, it is the interior that needs the work. It is a long term plan of mine to change my dashboard to make it more 5 like. The underlying structure is actually not a bad start. I am some way off doing this job, but it is being dreamed about and I am sourcing parts already.
SE5a 'Fancier'
Rust hater
Post by Rust hater » Tue Nov 27, 2018 11:33 am
Yes, the 5 dash looks more pure than 5a & certainly 6 series. Somewhere in my googling I found mention of a 5b but I guess that is b for bull****?
scimmy_man
Been thanked: 36 times
Post by scimmy_man » Tue Nov 27, 2018 12:46 pm
IIRC some one fitted a 2.8 injection to a SE5a and referred to it as a 5b
Pepe
Post by Pepe » Mon Dec 17, 2018 7:48 pm
3 spoke Steering wheel on SE5 looks WAY better than the bloody 2 spoke Unit in the 5a. Swapped against 5 wheel in my 5y.
But the 5a is made of thicker aluminium and potentially more sturdy...
Just broke my 3 spoke, which is obviously is not the only occasion where this happens...
personally I like the 5's front (lower and 4 pin "grille") and the 5a's rear (nicer rear lamps). And yet again I like the 70ies look of the 5as dash over the 60ies look of the 5.
I am happy with my 5a, would also love to have a 5 in addition, but would add to all others... get what you can afford. I gues still they are not yet a lot apart in terms of price.
Worth mentioning is the rearaxle which is 4HA in the later and 7HA in the earlier cars... change also was roughly with 5/5a. both are almost the same, but the 5as is a bit more rigid (if not rusted)....
5 or 5a is a lot of small changes. Nothing essential. :shock: 8)
OK Shoot... who throws the first stone :)
1975 SE5a restoration link
Image Image
roymck
Post by roymck » Mon Dec 17, 2018 8:46 pm
Only first 500 cars had the 7HA axle , and most early cars that are still running have probably had it changed by now . Also 5a rear lamps are expensive to replace and a nightmare to remove repair .
CarlosVanDango
Post by CarlosVanDango » Sat Jan 19, 2019 9:56 pm
is this correct?
i've looked at pictures an can't really tell a difference just seems to be where the photos been taken from :|
scimmy_man
Post by scimmy_man » Sat Jan 19, 2019 11:19 pm
the later SE5 onwards had slightly higher headlights due some minimum height thing.
petrolbob
Post by petrolbob » Sun Jan 20, 2019 1:39 am
The rest of the interior of the 5 is more robust. Doorcards are fibreglass as are the long interior side panels compared to plastic long panels on 5a.The gearbox of the 5 and some very early 5a was sourced from the Ford Zodiac not as good as the later box with better 2nd gear ratio.
Gearchange is different too, 2 rod on 5 and 3 on 5a. I lean towards the 5 as it was my first Scimitar but both versions are very worthy.
