Remove a car radio
Eric2205
Remove a car radio
Post by Eric2205 » Sat Oct 20, 2018 12:32 pm
Morning,
I have in my scimitar a car radio Clarion without MF and I found an old Senn-Sound with MF.
But I have a problem: I can not remove the clarion from behind the dashboard and I can not find or pass it
Do any of you have any advice?
David Tew
Been thanked: 24 times
Remove a car radio
Post by David Tew » Sat Oct 20, 2018 1:16 pm
You'll need a Clarion radio removal tool. There are various types so search Google for the correct one or get a complete set such as THESE.
RSSOC member since 1978. 😲
Been thanked: 86 times
Remove a car radio
Post by Coupe Racing » Sat Oct 20, 2018 1:25 pm
That's assuming it's a DIN fit
siw1800
Remove a car radio
Post by siw1800 » Sat Oct 20, 2018 2:54 pm
"MF"?
Simon Waddington
MGB - Gone
Daimler SP250 - Gone
SE5a - Gone
Sabre Turbo - Gone
Euro Box Estate - Gone
Rover 25 1.4IL - Gone
Company Astra Turbo Diesel Van Gone
Peugeot 307 CC HDI
Mazda MX5 - When Mother replaces it! - Went to the scrap yard in the sky
Company Peugeot Partner Van
Eric2205
Remove a car radio
Post by Eric2205 » Sat Oct 20, 2018 3:51 pm
It's an old clarion that I replace with a vintage car radio but has FM (band U)
Disassembly does not pose a problem, which blocks me it's I can not remove it from behind the dashboard
My old car radio
My new car radio
Been thanked: 319 times
Remove a car radio
Post by peter freeman » Sat Oct 20, 2018 4:04 pm
Looks like you will have to pull the panel out
Been thanked: 839 times
Remove a car radio
Post by scimjim » Sat Oct 20, 2018 4:24 pm
There’s a metal plate behind the dash on the 5a between the radio and the dash panel.
Edit - couldn’t see the picture but your plate obviously isn’t fitted but the dash hasn’t been cut out.
David Tew
Remove a car radio
Post by David Tew » Sat Oct 20, 2018 4:31 pm
Steve, you were right to be cautious - it isn't! :wink:
rebel alliance
Been thanked: 37 times
Remove a car radio
Post by rebel alliance » Sat Oct 20, 2018 4:48 pm
Emailed you David about timing gear cheers
Been thanked: 81 times
Remove a car radio
Post by Oldconn » Sat Oct 20, 2018 4:53 pm
It looks as though Eric will have to remove the centre panel of the dashboard.
David Tew
Remove a car radio
Post by David Tew » Sat Oct 20, 2018 5:20 pm
Gottcha, replied. :wink:
Ken Davies
Remove a car radio
Post by Ken Davies » Sat Oct 20, 2018 5:51 pm
The instructions start 'prise the steering wheel boss off and withdraw the steering wheel with a puller' and go on to remove the entire dash. There may be another way but I didn't see it when I swapped mine for a Retrosound. The opportunity for project creep is immense. Have fun 😊
1975 SE5a JTF843P, 1966 AH Sprite mkIII in progress
Been thanked: 459 times
Remove a car radio
Post by Roger Pennington » Sat Oct 20, 2018 6:09 pm
I don't have a 5a, but it's not like a 6a is it, where you can remove the standard radio by taking out the glovebox liner, and then taking the radio out sideways through the glovebox?
Eric2205
Remove a car radio
Post by Eric2205 » Sat Oct 20, 2018 9:23 pm
Thank you for yours answers
By the glove box it not possible
I think I must remove the dash...
Remove a car radio
Post by Coupe Racing » Sun Oct 21, 2018 8:50 am
The glove box liner is removable
