Starter Solenoid Relay
Eric2205
Post by Eric2205 » Mon Sep 24, 2018 10:03 am
Hi,
My SE5a is an automatic and the chassis number is 931060
Also my car must have two solenoids
"solenoid assembly, starter motor" and "starter solenoid relay"
Could you tell where I can find the "starter solenoid relay"
Regards, Eric
Has thanked: 120 times
Been thanked: 891 times
Post by scimjim » Mon Sep 24, 2018 10:04 am
If fitted, it’s on the inner wing just behind the battery. When Reliant changed the starters to pre-engaged type, they left the old solenoid on the wing (presumably to use up remaining stock of looms) and just ran a new wire to the starter. I’ve removed mine as it’s not really needed.
Item 18 - top left
Been thanked: 562 times
Post by philhoward » Mon Sep 24, 2018 10:16 am
They used it an a starter inhibitor relay - somewhat overkill but my ‘74 5a (Auto) had one. Was on the “shelf” somewhere by the wiper motor if I remember correctly.
Post by scimjim » Mon Sep 24, 2018 10:37 am
Battery > fuse box > wiper motor > starter relay IIRC? I have a battery kill switch where the relay used to be.
I don’t think the auto really needs a solenoid, you could fit a normal relay?
Edit - you can see it in this photo from Dave Poole’s sporting-reliant site.
Post by philhoward » Mon Sep 24, 2018 10:47 am
Yep - except on the auto it had the white/red wires for the starter solenoid where you’d expect to see the battery cables attached. I remember it because it seemed odd. Main battery cable went straight to the (pre-engaged) starter as normal.
Eric2205
Post by Eric2205 » Mon Sep 24, 2018 12:44 pm
Thank you for all this informations
I'll look on my car this evening
My starter and it's solenoid
David Tew
Post by David Tew » Mon Sep 24, 2018 1:58 pm
When I fitted a later-type starter motor to my Coupe I wasn't too keen on a permanently live high-amperage feed running between the block and the manifolds so I left the remote solenoid in place and put a link on the starter between the main feed and the solenoid connector. It works fine and gives me a little peace of mind - not that I'm a worrier! :wink:
Mind you, I do have long-branch manifolds and I think the cable is closer to them than the normal single down-pipe.
Eric, I'd give those connections a clean and remake the solenoid connector.
RSSOC member since 1978. 😲
Eric2205
Post by Eric2205 » Mon Sep 24, 2018 2:45 pm
I'm agree with you : the solenoid cooector must be remake and all connections must be clean
