lower wishbone remplacement SE5
Mimic
Post by Mimic » Tue Jul 24, 2018 5:36 pm
Hi,
I am going to renew the front suspension and steering on my early SE5. I need to change the lower wishbone bracket. I was a little bit pressed, so I bought reinforced se6 bracket. I haven't seen the bolts were not in the middle on the bracket . I think It 'll be affect the geometry if I fit these ones. Your help / experience are welcomed to give me the best solution.
NB:I dont' knew the difference between the SE5 et SE6 bracket ...so I bought 4 L/H brackets. Do you think I could make 2 new holes or it's better to order 2 R/H new ones?
Thanks for your help.
Mimic
SE5 french Owner
Been thanked: 842 times
Post by scimjim » Tue Jul 24, 2018 5:43 pm
SE6 brackets will alter the geometry. Send them back and order SE5a brackets.
Mimic
Post by Mimic » Tue Jul 24, 2018 6:13 pm
On left side I have 2 sort of bracket. Have you a picture of the good ones on a SE5 ?
Does exist reinforced SE5 bracket with symmetrical holes?
Post by scimjim » Tue Jul 24, 2018 6:28 pm
I’m not sure if you can still get SE5 brackets - SE5a have a change to the roll centre (the hole is at a different height). The studs on 5/5a are central.
Mimic
Post by Mimic » Tue Jul 24, 2018 6:41 pm
The perfect ones will be these I think :
Been thanked: 320 times
Post by peter freeman » Tue Jul 24, 2018 7:56 pm
I have a 4A and the brackets are slightly different from the 5A brackets - the brackets are fitted in a recess in the chassis. The difference between them and the 5A bracket is however only slightly different so I think I could use 5A brackets without any problems - the 6 brackets being offset are not suitable however so don't use them - as Jim says send the offset bracket back and ask for 5A ones.
GeoffTE
Been thanked: 24 times
Post by GeoffTE » Tue Jul 24, 2018 9:06 pm
Here’s a pic of the 5 and the 5a brackets side by side. I fitted the much stronger 5a brackets to my 5 (SAR) even though you can see the hole in the 5a bracket is a little lower.
The effect on the geo is minimal and can be compensated for by other adjustments. All the geo measurements on SAR are within tolerance
Geoff. (5324)
Mimic
Post by Mimic » Fri Jul 27, 2018 2:00 pm
Thank you for your answer.
I have same configuration like the last picture : a mix between SE5 / SE5a bracket. I am going intend to return the SE6 ones.
Scimicalement
Mimic
