5 /5a chassis
briankenyon
5 /5a chassis
Post by briankenyon » Fri Jun 08, 2018 10:28 pm
Are there any differences between 5 / 5a chassi
Ie - width or length any thoughts would be appreciated.
Brian
scimmy_man
Been thanked: 33 times
5 /5a chassi
Post by scimmy_man » Fri Jun 08, 2018 10:42 pm
the crossmember under the sump changed from a tube to a flat plate when the later engine (rear sump) was fitted, also the engine mounts changed from bolt on to welded on,
in effect both are interchangable with a bit of fiddling.
briankenyon
5 /5a chassis
Post by briankenyon » Fri Jun 08, 2018 11:44 pm
Thankyou.👍👍
I've just lifted body off chassi (needs work)
I have a good chassi off a 5a and thinking I may use it may save a lot of time and beer tokens
5 /5a chassis
Post by Oaksey » Sat Jun 09, 2018 2:57 pm
Personally, I'd make the 5 chassis good. It's always nicer to have a more original setup and it'll probably save time in the long run as you know that the body and chassis fit well :)
briankenyon
5 /5a chassis
Post by briankenyon » Sun Jun 10, 2018 8:52 am
Hi.
The car was originally a auto
Bought the car with no gearbox,however a manual gearbox had been fitted (supported by household electrical wire hang from the bulkhead)
A replacement engine was also with car(Not fitted)and in bits so will need a rebuild. None original
My intentions are to covert to manual and fit a later engine, with the later chassi having the engine mount and cross member support in it's proper position
Thinking🤔wouldn't it be feasible to use the later chassi.
Or would I have problems fitting the body ??
Brian
Has thanked: 85 times
Been thanked: 59 times
5 /5a chassis
Post by efi_sprintgte » Sun Jun 10, 2018 9:00 am
I’ve Known a few 5a shells with 5 chassis and wasn’t aware of any major dramas.
I’m aware you intend to do the reverse. Can’t see it being an issue, I would do what practically suits you best.
ID stays with the chassis of course...
briankenyon
5 /5a chassis
Post by briankenyon » Sun Jun 10, 2018 9:21 am
Hi.
Can't find any ID on the chassi 🤔
Does anyone reconize these electric connections??
Thanks brian
Been thanked: 876 times
5 /5a chassis
Post by scimjim » Sun Jun 10, 2018 1:50 pm
Aftermarket plugs - looks like the chassis has been refurbished, so ID is either under all that nice paint or has been removed :W
briankenyon
5 /5a chassis
Post by briankenyon » Sun Jun 10, 2018 1:59 pm
Hi Jim
Stripped back some of the wiring and under investing it would seem extra cablefitted to original loom
Makes me wonder what for ??
Brian
5 /5a chassis
Post by scimjim » Sun Jun 10, 2018 2:45 pm
Looks like it was done well though? (On my phone, so can’t see in detail)
Rattling
Been thanked: 14 times
5 /5a chassis
Post by Rattling » Sun Jun 10, 2018 4:14 pm
Just a guessing tow electrics ?
Colin
1800 Ti
Been thanked: 89 times
5 /5a chassis
Post by gtcse8 » Sun Jun 10, 2018 5:33 pm
Shame on you Jim, you should have noticed the Nato/Mod multi pin conector, especially when its resting on the wheel.
Quite obviously a replacement for the original rotted out Lucar plug socket for the rear electrics inc lights.
ID is stamped on the front of the turret OPPOSITE to the one in the pic with the spanner on it.
briankenyon
5 /5a chassis
Post by briankenyon » Sun Jun 10, 2018 9:23 pm
Thanks for the info 👍👍
Brian
roymck
Been thanked: 23 times
5 /5a chassis
Post by roymck » Thu Jun 14, 2018 6:22 pm
I had a early pre 500 SE5 with a late 93X chassis under it , no problem
briankenyon
5 /5a chassis
Post by briankenyon » Thu Jun 14, 2018 6:43 pm
Yes mate
Thanks for the info
Think I'm going to use this later chassi I have
Possibly save a lot of time and money
