rear brake sliders
kapri
rear brake sliders
Post by kapri » Fri May 25, 2018 3:30 pm
Help !! How do these go together ? By copying the other side ( in reverse) I have fitted the distance piece and repatinder but I'm really stuggling on ho wto fit the spring retainer .
Does it come in from the handbrake lever side and 'forks' up or down ?
Any tricks I'm missing and I presume the rubber seal goes on last ?
Been thanked: 842 times
rear brake sliders
Post by scimjim » Fri May 25, 2018 3:39 pm
How to here - I’ll copy it into the how to guides when I get back from walking the dog :D
kapri
rear brake sliders
Post by kapri » Fri May 25, 2018 3:54 pm
Problem as I don't have the manual numbering which is which ! LOL
On the photo which is which please and what is up / down compared with handbrake lever please ?
Last time I worked on brakes with sliders like these was on a Sunbeam Alpine sports back in 72 !
rear brake sliders
Post by scimjim » Fri May 25, 2018 4:40 pm
I’m not sure which manual it’s referring to (there are a few) but the parts list is quite good for orientation, and is on the GW site.
Edit - autobooks as mentioned in the link :oops:
Ipad links here
kapri
rear brake sliders
Post by kapri » Fri May 25, 2018 8:50 pm
Sussed it :) It goes against logic as you look at expect it to fit in order 1, 2, 3 and it actually goes 1,3 and then fit 2 to keep it all in place. :) Thanks for all clues .
