Advice where rear Seatbelt mounting brackets fit SE5
1969SE5
How do you retro fit Rear Seatbelts to an SE5 ?
Post by 1969SE5 » Tue Mar 20, 2018 11:23 am
think i will stick with a lap belt, with the bracing off the later cars, once i can get some used or fabricate some.
turbster
Post by turbster » Tue Mar 20, 2018 1:24 pm
This is where the idea for a bar behind the seats came from, I fitted this to my Landy to fit some proper seatbelts..
LRP 335E SE4a
XRF 976H SE5
DBY 119M SE5a
Been thanked: 854 times
Post by scimjim » Tue Mar 20, 2018 8:50 pm
I fitted similar down both sides in my Def 90 to secure 4 point harnesses to the side facing seats - the kids loved them :-)
The problem in a 5/5a is the lack of anywhere high enough to give the correct angles over the shoulder, coupled with the lack of any lateral guide apart from the passengers shoulder.
turbster
Post by turbster » Tue Mar 20, 2018 9:32 pm
You’d probably end up with the top mount being suspended high enough to be visible through the window.. I’m definitely having a go so we’ll see :wink:
LRP 335E SE4a
XRF 976H SE5
DBY 119M SE5a
1969SE5
Wanted : Rear Seatbelt mounting brackets SE5
Post by 1969SE5 » Thu Mar 22, 2018 10:07 am
Morning All
changed the title to Wanted.... just need the brackets.... any donor cars out their, photos of the inner and outers ? are we happy the inners and outers are the same, so do I need to copy 4, or 2 sets of 2? measurements anything , all help gratefully received. :D :D
Stephenl
Post by Stephenl » Fri Mar 23, 2018 2:59 am
I too am interested in a similar project- another shout for measurements (and if more than one set of straps show up for sale, Im interested in the spare ones)
'69 SE5
Geraint SabreGTCse5
Been thanked: 35 times
Post by Geraint SabreGTCse5 » Fri Mar 23, 2018 7:30 am
do you need the chassis to s/b metal straps for the rear seats lap belts, I have some somewhere I could sell on
Geraint
Sabre ti, se5, GTC, 6b.......
1969SE5
Post by 1969SE5 » Fri Mar 23, 2018 8:54 am
PM sent
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Fri Mar 23, 2018 1:11 pm
these are what you need I have a few sets knocking about...
Geraint
Post by scimjim » Sat Mar 24, 2018 8:39 am
There are also load spreader plates at the forward ends (where it sandwiches GRP between the brackets and seat belts). Being so exposed, lots of people make replacements from SS.
1969SE5
Post by 1969SE5 » Sat Mar 24, 2018 10:57 pm
thanks Jim, useful to know.
1969SE5
Post by 1969SE5 » Mon Mar 26, 2018 4:07 pm
arrived in the post today !! been on the wire wheel at work, paint tonight...... many thanks Geraint :D
1969SE5
Post by 1969SE5 » Wed Mar 28, 2018 11:55 pm
Right, daft question time..... How do these mount, had a look on the car and they appear to lend themselves to the longer ones to the outer (sill) side, and going to the side of the rear seat tub. And the shorter ones do the inner, but going to the bottom of the rear seat tub ?? Is that correct ? Obviously I have no holes to work to, as not fitted previously. All help gratefully received, as ever.
1969SE5
Post by 1969SE5 » Thu Mar 29, 2018 1:09 pm
please.... ?
Been thanked: 540 times
Post by philhoward » Thu Mar 29, 2018 1:14 pm
Pretty sure they both mount on the side of the seat tub.
