Fuel pipe fittings?
Fuel pipe fittings?
Post by Roger Pennington » Fri Feb 23, 2018 1:06 pm
Is it true that what I'm told, that those mysterious objects known as "modern cars" still use nylon pipes? :)
Been thanked: 535 times
Fuel pipe fittings?
Post by philhoward » Fri Feb 23, 2018 1:07 pm
They do..
747PETE
Has thanked: 30 times
Fuel pipe fittings?
Post by 747PETE » Fri Feb 23, 2018 1:20 pm
One other reason I went for Kunifer was the fact with the right tool,it can be formed and bent to fit,unlike the nylon type I found.True it’s quite hard to form with the fingers and has to be straightened out first off all.Needless to say,it was fun on my back continuously feeding the long line into place then removing it to check and form😀
Been thanked: 210 times
Fuel pipe fittings?
Post by AJL Electronics » Fri Feb 23, 2018 1:20 pm
Nothing wrong with nylon. Just be careful not to kink it and it will be as good as Kunifer.
747PETE
Fuel pipe fittings?
Post by 747PETE » Fri Feb 23, 2018 1:47 pm
The Kunifer stays there now,if nylon is easier Imight usethat onthe next one.........
Fuel pipe fittings?
Post by AJL Electronics » Fri Feb 23, 2018 4:01 pm
I have done my project in Kunifer, so I'm not knocking it, just saying that there is no need to worry about the factory fit nylon.
