Stuck in Second
Covpath
Stuck in Second
Post by Covpath » Mon Feb 19, 2018 8:00 am
Hi Team
My SE5a is stuck in second. All was well apart from gear changes being a bit stiff when it decided to remain in second. Gearstick flaps around front to back but not much left to right movement. Any ideas for most likely cause? Will I see more by getting it over an inspection pit - care of my capable friend Geoff?
Thanks++
Paul
Been thanked: 540 times
Stuck in Second
Post by philhoward » Mon Feb 19, 2018 8:06 am
Assuming it's the 3 rod box then it's a pretty safe guess it's current only got 2 rods connected (correctly)..
Covpath
Stuck in Second
Post by Covpath » Mon Feb 19, 2018 8:21 am
I'll have access to an inspection pit later in the week. From p67 in the manual it looks like I'll be able to see the problem from below? I'll let you know how i get on.
Thanks again
Paul
Stuck in Second
Post by philhoward » Mon Feb 19, 2018 8:40 am
It should become self-evident which one is flapping around that shouldn't be. It is likely to be where the lever bolts onto the side of the gearbox - they're slotted where thy fit onto the stub comes out of the side plate, and supposed to be held on with a Nyloc nut from memory. Be careful that the stub doesn't fall back into the gearbox otherwise I think it's fun and games time trying to get all the detent balls and springs back in where they should be..
Covpath
Stuck in Second
Post by Covpath » Mon Feb 19, 2018 5:00 pm
Thanks again
BW
P
:D
Covpath
Stuck in Second
Post by Covpath » Tue Apr 17, 2018 2:58 pm
All sorted thanks to the DemiGod in Kettering!!
Stuck in Second
Post by philhoward » Tue Apr 17, 2018 3:38 pm
We are all itching to know what the problem was?
Well, I am..
