How to remove a gearbox from a SE5a
Post by DARK STAR » Mon Feb 26, 2018 6:58 pm
Sorry I have forgotten how much oil an auto box takes, but it is quite a lot.
If you fill it from the side like a manual you just add oil until it comes out ...
Désolé j'ai oublié combien d'huile ça prend une boite auto, mais c'est beaucoup.
Si on la remplie d'à coté comme une manuelle on rajoute d'huile jusqu'à ce qu'elle ressort ...
Post by DARK STAR » Mon Feb 26, 2018 7:02 pm
PS just looked it up, capacity is 8 litres but even if you drain it there will remain some oil, so about 7 litres.
PS je viens de me renseigner, la capacité c'est 8 litres, mais meme si on fait la vidange il en resterait de l'huile, alors à peu près 7 litres.
Been thanked: 840 times
Post by scimjim » Mon Feb 26, 2018 8:17 pm
Haven’t checked the manual but I’m pretty sure you fill through the dipstick tube and there’s a certain way to check the level (engine running on one type, engine off on the other).
All explained in the workshop manual I expect?
Eric2205
Post by Eric2205 » Tue Apr 17, 2018 2:06 pm
Hi,
Some news of the scimitar: the replacement of the "rear servo body" has not corrected my problem of reverse ...
So I decided to buy a new gearbox (with a new torque converter)
But there was a problem during transport: the body of the gearbox was broken.
I should finally receive my new gearbox in the week.
Hopefully I'll be able to drive my Se5 in May
Been thanked: 534 times
Post by philhoward » Tue Apr 17, 2018 2:08 pm
:shock:
Eric2205
Post by Eric2205 » Tue Apr 17, 2018 2:19 pm
I'm agree with you...
Post by DARK STAR » Tue Apr 17, 2018 4:03 pm
Bad luck Eric, that's incredible.
Has thanked: 53 times
Been thanked: 85 times
Post by b.c.flat hat » Tue Apr 17, 2018 6:12 pm
That's extreme negligence if it arrived like that, some serious impact damage sustained.
Best o' luck to you and here's hoping for a swift and successful outcome.
Been thanked: 86 times
Post by Coupe Racing » Tue Apr 17, 2018 6:15 pm
it was dropped from height by the looks of it
Been thanked: 319 times
Post by peter freeman » Tue Apr 17, 2018 7:26 pm
You do fill the auto box through the dipstick tube - you have to run the engine and move though all the gears to get the oil to circulate then check the level on the dipstick and add oil to get the level right. There are also two types of oil for the auto box - which type you use depends on the colour of the knob on the dipstick. Best ask the supplier of the gearbox which oil it needs. I have the info "somewhere" but it will take time to find it. Roger will remember without having to search no doubt.
Post by peter freeman » Tue Apr 17, 2018 8:41 pm
Found it - red then Dexron - black then Ford M2C-33G - I think.
Post by scimjim » Tue Apr 17, 2018 8:50 pm
It’s the C3 boxes that have different coloured dipsticks and can take Dexron in the later versions.
Eric2205
Post by Eric2205 » Wed Apr 18, 2018 7:41 am
C'est une Borg et Warner et pas de Dexron
