SE5a Fusebox Error
Rev Light
Been thanked: 23 times
SE5a Fusebox Error
Post by Rev Light » Mon Jan 29, 2018 2:08 pm
All,
I have recently acquired a used SE5A fuse box, courtesy of Phil Howard (visa ScimJim). Jim mentioned he seemed to recall that there was a labelling issue, on the top of the fusebox, with regard to the fuse allocation. Any thoughts?
I have tried to search this sight, but nothing is leaping out. Although there is a witness mark on this assembly that might indicate that there was a sticker over contacts 5,6, 7 and 8 (Parking/Side and tail lights?)
SE5a 'Fancier'
Been thanked: 535 times
SE5a Fusebox Error
Post by philhoward » Mon Jan 29, 2018 2:16 pm
I think a quick look at the handbook, Peter Freemans wiring diagram and cross reference to the cover tells all. There were subtle changes over the years but I think that was relating to the commoning across some of the fuses on the back rather than the actual function (relating to the change in headlamps and whether they were sealed beam, halogen or when they added the main beam relay.
Rev Light
SE5a Fusebox Error
Post by Rev Light » Mon Jan 29, 2018 2:33 pm
Thanks Phil,
Not that my 5A is wired as 'standard'. Its is over 40 years old, after all.
SE5a 'Fancier'
SE5a Fusebox Error
Post by philhoward » Mon Jan 29, 2018 2:36 pm
Neither is mine (now) - so hardly an accurate point of reference either!
Does that help?
SE5a Fusebox Error
Post by Roger Pennington » Mon Jan 29, 2018 3:45 pm
I think if you search Geoff Cooper's old posts there may be something about it - ISTR it was something he had strong views on? :)
SE5a Fusebox Error
Post by philhoward » Mon Jan 29, 2018 3:48 pm
I think it was on some 5a's the fuses were actually connected in serial (something like LH dip fuse fed the LH lamp and the RH dip fuse?) which was actually a wiring fault.
Steve - I've no idea what year/spec that fusebox came from - but if you've done the sensible thing and relayed the headlights anyway then it shouldn't make much difference?
SE5a Fusebox Error
Post by Roger Pennington » Mon Jan 29, 2018 3:49 pm
Well, that was a wiring issue, maybe this thread and this other thread may be what you're after?
SE5a Fusebox Error
Post by philhoward » Mon Jan 29, 2018 4:02 pm
That's the issue I was thinking of.
IIRC, Steve is actually replacing an aftermarket fusebox with an original, so should be able to correct the problem if it does exist on his?
Been thanked: 842 times
SE5a Fusebox Error
Post by scimjim » Mon Jan 29, 2018 6:03 pm
So there’s two problems - the 15/16 blue/red error that Geoff highlighted and fuse 11/12 that is annotated headlamps on the cover, but isn’t.
