Brake caliper/disc upgrade options
Toecutter
Post by Toecutter » Fri Dec 08, 2017 9:14 pm
Yo! Is anyone running a modern front brake setup on their SE5's of 1974 era? If so, what vehicles can you recommend for decent setup? Adaptation on any level, not a problem as can fab etc.
Many thanks,
T
Been thanked: 321 times
Post by peter freeman » Fri Dec 08, 2017 9:32 pm
I think the 5 brakes are good enough - better than the 6's. Wilwoods will be the other option I would go for - got them on my MB.
Toecutter
Post by Toecutter » Fri Dec 08, 2017 9:57 pm
Ok cheers for the info. I'm still yet to drive it ye'see so I haven't experienced the stock braking system ( or scimitar driving at all :( ) I thought, whilst I have easy access to everything while the body is off and everything stripped down an upgrade would have been viable instead of rebuilding the girling calipers.
Cheers peter
turboscim
Post by turboscim » Sat Dec 09, 2017 11:21 am
Standard in top condition with good top brand pads [mintex,ferodo] probably o k for normal use.
For hard use 4 pot vented wilwoods with top pads.
For trackday I add cooling ducts to disc and caliper.
Most important is the pad make and compound.
IMHO.
Been thanked: 66 times
Post by Scimher » Sat Dec 09, 2017 11:29 am
The '3-pot' Girlings were used on the Aston DB5 & other high performance cars of the era, I believe......My 5 has the original set-up with Goodridge hoses & the feel is brilliant. I'd save the energy & expense for other areas of renovation/improvement/upgrade etc.
