se5a stub axle
halfpenny
se5a stub axle
Post by halfpenny » Mon Dec 05, 2016 6:27 pm
I have what is clearly a bitsa, and I need to identify wheter I have big or small front stub axles. Does anyone have a diameter dimension, or alternatively could someone measure a known big or known small outer end. Many thanks.
Has thanked: 186 times
Been thanked: 1264 times
Re: se5a stub axle
Post by scimjim » Mon Dec 05, 2016 10:19 pm
According to Joe/Dave, late ones are
inner bearing between 1.0" to 0.9995" (25.4mm - 25.37mm), outer bearing between 0.75" to 0.7495" (19.05mm - 19.04mm)
halfpenny
Re: se5a stub axle
Post by halfpenny » Tue Dec 06, 2016 8:41 am
Many thanks Jim. If I have small end, I'll post the diameter.
halfpenny
se5a stub axle
Post by halfpenny » Mon Sep 17, 2018 10:59 am
Finally got around to checking this. OS has 3/4 outer end to stub axle. NS has 5/8 ( ie the smaller diameter). No surprise given the general mismatch of components on my car.
