SE5a Dashboard removal
DarrylWebb
Has thanked: 70 times
Post by DarrylWebb » Sat Sep 12, 2015 8:28 am
To remove the 5a dashboard carcass, how do you remove the bolt behind the glovebox? It's so inaccessible I'm hoping I'm missing some secret access panel.
Been thanked: 86 times
Re: Dashboard removal
Post by Coupe Racing » Sat Sep 12, 2015 9:00 am
Thought the glovebox liner was removable or am I mixing it with another model
Been thanked: 535 times
Post by philhoward » Sat Sep 12, 2015 9:09 am
There's at least one access hole in the side of the glovebox - peel back the carpet inside to reveal.
Been thanked: 842 times
Post by scimjim » Sat Sep 12, 2015 9:54 am
Yep - 6 series glovebox comes out as one piece, 5 series is carpet glued onto the carcass hiding the secret access holes.
Post by Coupe Racing » Sat Sep 12, 2015 11:12 am
A yes I recall now
Have owned both and got muddled
DarrylWebb
Post by DarrylWebb » Sat Sep 12, 2015 12:45 pm
Bingo. Got it now. Thanks, chaps.
Post by scimjim » Sat Sep 12, 2015 2:25 pm
Pics for "how-to" thread? :mrgreen:
DarrylWebb
Post by DarrylWebb » Sat Sep 12, 2015 7:18 pm
If you insist :D
To get the dash out of an SE5a, there are 8 fittings to remove (assuming any previous owner has put them all back).
6 of them are into captive fittings : handy, but a PITA if they seize and pull the captive fittings out. The captive fitting is a nut welded to a small steel plate affixed with 2 rivets, so can easily pull out if you force it. Be Careful!
7/16" sockets or spanners through-out BTW.
On the right, through the carcass into the A-post area of the shell are 2 bolts.
Similar on the left. In this case that's a rather large 'adjustment' hole.
Behind the instruments, a bolt goes through here. The bolt also holds a metal P-clip for the wiring loom. This makes getting onto the bolt head a pain : Knuckle joint and long extension required.
Mirrored on the left another bolt, but now it's behind the glove-box. No need to grow a second wrist : peel back the carpet in the glove box to reveal. Knuckle joint and long extension needed again get onto this one properly. Take great care with this one. If this seizes, getting power tools in is going to be tricky.
A couple of easy fitting 'cos you can get onto the front and back of these. A steel strap from the bulkhead bolts up to this hole right of the air vent.
Ditto on the left.
Post by scimjim » Sat Sep 12, 2015 10:07 pm
Excellent :-)
Post by Roger Pennington » Thu Sep 17, 2015 12:29 am
Darryl, I've made the thread a sticky :)
DarrylWebb
Post by DarrylWebb » Fri Sep 18, 2015 6:48 pm
Ta,Roger. This is for SE5a, so if anyone spots SE5 differences, feel free to chip in.
Re: SE5a Dashboard removal
Post by Coupe Racing » Fri Sep 18, 2015 9:20 pm
SE5 is so different
