Se5 Gear Selector Mechanism
stevmale
Post by stevmale » Fri May 22, 2015 12:03 pm
Hello .
I am renovating a Se5 gearbox . The only problem is a over loose selector and the usual oil leaks.
My original intention was to replace this unit with a type 5 Ford gearbox from another scimitar I own.
But the option of a selector mechanism overhaul and oil replacement appeals to me.
Are the spares available for this gearbox or is it a week end on the lathe !!
And whas the opinion of these gearboxs.
Currently - SE6 3.4 for Sunday morning's + Coupe for the track .
Previously - 4 x SE5's
[album]1656[/album]
Has thanked: 153 times
Been thanked: 1042 times
Re: Se5 Gear Selector Mechanism
Post by scimjim » Fri May 22, 2015 12:27 pm
Excellent box IMO - I made up rose jointed rods for 8 ball.
stevmale
Post by stevmale » Fri May 22, 2015 1:41 pm
I have found this picture on the on the web.
[album]1656[/album]
Post by scimjim » Fri May 22, 2015 2:14 pm
Yes, here's mine
Taggers
Post by Taggers » Fri May 22, 2015 2:26 pm
I used little ball joints and clevis joints. M10 stainless threaded bar is good, because once you get it bent, it stays bent.
Chris.
1979 SE6A
stevmale
Post by stevmale » Fri May 22, 2015 5:53 pm
Are they known as a Dagenham box.
[album]1656[/album]
Post by scimjim » Fri May 22, 2015 6:02 pm
it might be but I've never heard it called that. AFAIK it's a 2604E with an LH overdrive.
Edit - Google suggests not, the "Dagenham box" is a 4 speed from a Mustang?
Stephenl
Post by Stephenl » Fri May 22, 2015 6:31 pm
I have the same gearbox/o/d combination. These are fitted to some coupes and early SE5's. The switch for the O/D (to ensure it works in 3 and 4 only) and the reversing light is on top at the front. They have the L/H O/D not the J. I have a bunch of pictures at home I can post, they are already on here somewhere though.
Later cars have the box with the rods entering the gearbox at the side, that's the one don Kennedy rose jointed and was excellently written up on a webpage.
To make your selection snappier you can rose joint those 2 rods. I used a hollow rod and a rose joint with a male thread. I tapped out the inside of the rods and bent them appropriately to clear the gearbox and OD/ There is also meant to be a nylon bush inside the little square at the base of the gear lever; that's a make it yourself kind of thing i suspect. I didn't know that was meant to be there so missed my chance.
O/D is pretty easy to rebuild, in so much as parts and skilled vendors are available. I got mine done. The gearbox I also had rebuilt, I got it stripped down, I got a shopping list and luckily I was able to get all the parts I needed.
'69 SE5
Stephenl
Post by Stephenl » Fri May 22, 2015 6:36 pm
http://www.scimitarweb.co.uk/sgwrs/view ... 5&start=45
This thread might help,. I can't see it for some reason.
'69 SE5
Post by scimjim » Fri May 22, 2015 6:41 pm
Later box is a type Z (a type 5 body with different extension housing) with J type overdrive. 4 speeder is a type 5.
You can't view that thread because it's archived in the members section Stephen.
windy
Been thanked: 41 times
Post by windy » Fri May 22, 2015 7:42 pm
Jim, that Dagenham gearbox image above is a little misleading, they usually have side levers & different tailshaft housing fitted, so they look a lot like "our" 3 side lever gearboxes , albeit with a lever missing.
Not sure if they were available with O/D though.
http://www.bearingkits.co.uk/FORD-GEARB ... 58-1-0.htm
Post by scimjim » Fri May 22, 2015 7:44 pm
More like the later Z type then.
stevmale
Post by stevmale » Sat May 23, 2015 10:15 am
Hello.
Does anybody know if you can remove the gear box and leave the bell housing in position.
It looks possibly!!!.
[album]1656[/album]
Has thanked: 74 times
Been thanked: 687 times
Post by philhoward » Sat May 23, 2015 10:17 am
With an SE5, yes. Gear-lever needs to come off first I think (big bolt and don't forget the tiny lock-bolt), and a good wiggle?
Stephenl
Post by Stephenl » Sat May 23, 2015 4:02 pm
Yep I did it, several times. Forgot the gear lever too, so that's a good tip! Put a trolley jack under it and slide back, or you are good at bench presses...?
and here is my rose jointed gearbox; a work of art!
'69 SE5
