Se5 Fuse Ratings
Se5 Fuse Ratings
Post by Roger Pennington » Fri May 02, 2014 7:12 pm
Jim's list of Se5 fuse ratings copied from another thread and stickied for reference:
not sure if this is stickied or not but I will copy it here again:
From the top:
Overdrive - 10A
Side, panel & number plate lights - 10A
Heater motors, wipers/washers, reverse lights, fuel & temp gauges, indicators & brake lights - 50A
Horns, HRW, headlamp flash, bonnet light, cigar lighter & clock - 50A
The lower carrier fuses are arranged:
Main beam warning light & outer main beams - 50A
Inner main beams - 50A
LH outer dip - 25A
RH outer dip - 25A
the 25A & 50A fuses seem excessive to me on the headlights - the top two presume that everything is turned on at once, so won't protect much in isolation IMO.
Been thanked: 535 times
Re: Se5 Fuse Ratings
Post by philhoward » Fri May 02, 2014 7:13 pm
Quick addition - Glass fuses are rated at their "blow" rating which are the figures given above. Continuous rating is half that above figures.
