immersion heater question
Has thanked: 31 times
Been thanked: 126 times
Post by Coupe Racing » Tue Apr 21, 2020 9:24 am
A question to the wise please.
currently , my Immersion heater is controlled by a timer.
Most of my hot water usage - IE shower , dishwasher , washing machine etc are cold water fed.
However now I'm at home for the foreseeable future , I am running out of hot water during the day.
The question:
If the Immersion heater is left permanently ON , will it regulate itself and only heat the water when required ?
I'm in fear of running up an un-necessary electric bill.
Many thanks
David Tew
Has thanked: 24 times
Been thanked: 69 times
Post by David Tew » Tue Apr 21, 2020 9:40 am
Hi Steve,
The immersion heater does have a thermostat built in so it will keep the water at a set temperature. The thermostats do fail occasionally but are easily changed. There is a theory that, presuming well insulated storage, it's cheaper to keep a quantity of water hot than heat it from cold - that's the principle of boiling water taps in kitchens.
If you're concerned about leaving it on permanently, just extend the timer on/off periods to, say, 1 hour on / 1 hour off.
Has thanked: 103 times
Been thanked: 805 times
Post by philhoward » Tue Apr 21, 2020 9:43 am
They’re thermostatically controlled anyway? It will keep maintaining the water temperature even when you’re not going to use it so I’d alter the timer to be on more often - or does it have a “boost” function, turning it on for an hour or so every time you prompt it?
All depends on your timer
Post by Coupe Racing » Tue Apr 21, 2020 9:43 am
The current period provides good hot water for the duration of operation.
I will monitor and see how things go leaving it on.
Many thanks
Post by Coupe Racing » Tue Apr 21, 2020 9:44 am
Hi Phil
its a basic timer , so only 2 x on/off
Thanks for the thoughts
Post by philhoward » Tue Apr 21, 2020 9:44 am
Beaten by David but I think we’re saying the same thing of sorts 8)
Post by philhoward » Tue Apr 21, 2020 9:47 am
For years I ran one off a plug in timer with those 96 segments - but depends if you have a 13A socket nearby and happy rewiring it to a normal 13A plug? Then you can set it to come on for half an hour every 4 hours during the day.
Check the heater but they’re usually 2kw or 3kw - within the scope of a 13A setup.
Post by Coupe Racing » Tue Apr 21, 2020 10:15 am
Yes there is a 13A socket there .
Today I have set up an energy monitor .
After a few days I will change the settings on the Immersion heater to permanently on and compare the readings
I expect a small increase but if its massive then I will change the timer
Drury
Post by Drury » Tue Apr 21, 2020 10:31 am
Yes, it has a thermostat (water will boil if it's faulty.
