Cable rating - domestic
Has thanked: 31 times
Been thanked: 125 times
Post by Coupe Racing » Mon Nov 18, 2019 8:24 am
Hi a question about 3 core single phase wiring rating please ?
I would like to run armour cable from my house to my garage .
There is already old cable above ground but I want to start from scratch and bury armour cable
The garage runs 7 double 13A sockets , 14 six foot fluorescent tubes.
I occasionally run a welder that is marketed as 150A.
The distance from supply to fuse box will be approx 40m
Not sure if I need 2.5mm or 4mm armour cable .
Many thanks
Dave 6726
Has thanked: 54 times
Post by Dave 6726 » Mon Nov 18, 2019 9:09 am
If I were doing it, 4mm. You know your own usage patterns, but if I had that size of workshop I might even consider 6mm. May be considered over-engineering, but you could install it and forget it.
Been thanked: 417 times
Post by peter freeman » Mon Nov 18, 2019 9:11 am
I used a poly water pipe to run the cable in to keep the water out - go for 4mm rather have too much capacity than too little - the 150amp will be at 50 volts not mains supply of 240 volts
Has thanked: 102 times
Been thanked: 803 times
Post by philhoward » Mon Nov 18, 2019 9:19 am
What's your upstream breaker (on your consumer unit) for this circuit - 16A or 32A?
2.5mm will just about do the job (depending on how it's buried - direct, in pipe/conduit or an open trench), but if going to the trouble of putting a cable in then put 4mm as there's nothing worse than volt drop issues - especially with welders.
tony1966
Post by tony1966 » Mon Nov 18, 2019 11:47 am
you can help on the lighting load by using led strip lights-very low consumption,cheap to buy too if you order from the far east
Has thanked: 213 times
Been thanked: 46 times
Post by willholderogri » Mon Nov 18, 2019 12:11 pm
4mm or 6mm your choice ( I would use 6mm ) fluorescent are low current so no real need for led as they are pricy at he moment. I have 15 fluorescent in five banks of three no problem even with a welder and compressor as long as you don't run them together.
David Tew
Has thanked: 24 times
Post by David Tew » Mon Nov 18, 2019 12:57 pm
SWA is the stuff you need. 40 metres is a fair old run so I'd definitely use 6mm minimum, especially if it's buried as you'll need to downrate it. I presume you have a CCU in your garage and I'd ensure the RCD for the sockets is rated at 20A to protect the SWA. This will be fine for the ring as long as you don't plug everything in at once!
I use TLC for my electrical bits. Good quality and rarely beaten on price. They even have a handy cable-size calculator HERE.
I must admit I always use LED battens now as they use much less power and this might be important in your installation. They are more expensive though so it's personal choice really.
Have fun. :wink:
Post by willholderogri » Mon Nov 18, 2019 5:25 pm
I have an led Batton in my hobby room and it's fantastic so much light it makes it ideal for working on my electronic
projects .
cookieboy
Post by cookieboy » Mon Nov 18, 2019 5:37 pm
Shop around for prices .6mm 3 core is more common than 4 mm and buy a 50 metre drum as the wholesalers price by metres and charge for cutting in most cases.
Currently scimitarless .
Sabreite
Post by Sabreite » Mon Nov 18, 2019 8:28 pm
I agree with David when I put the electric into my garage/workshop I used 6mm armoured cable underground, I also ran a ring main with plenty of double sockets, in 4mm twin and earth to make sure the welder had enough power. The only problem is fitting the larger copper cable into the 13amp sockets it’s doable but not the same as installing 2.5mm cable. Also if you are going underground put the yellow warning tape (caution electric cable below) a few inches above the cable in the trench saves a problem in later years. I get all my bits from TLC they are very good on price and quality.
John
Has thanked: 167 times
Been thanked: 1169 times
Post by scimjim » Mon Nov 18, 2019 8:56 pm
I have dedicated blue 16/32A Commando sockets for the compressor, tyre machine and welder, you could wire them in 4mm - and run a separate 2.5mm ring main for household 3 pin sockets and lighting?
Post by Coupe Racing » Wed Nov 20, 2019 10:44 am
Thank you to all who replied via PM and the forum.
To be safe and to future proof I will use 6mm
Thanks again
Post by Coupe Racing » Sun Mar 08, 2020 1:22 pm
Just a Quick revisit now I have got round to doing this.
Should I order 2 or 3 core ?
Post by philhoward » Sun Mar 08, 2020 1:43 pm
Using 2 core relies on using the armour as earth so personally I’d use 3 core - known as single phase 3 core so the colours are correct.
Post by Coupe Racing » Sun Mar 08, 2020 1:55 pm
ok - just wanted to make sure - thank you
