Car Cover
Terryilett
Car Cover
Post by Terryilett » Sat Jun 08, 2019 11:51 am
Thank you all for your advice. As much as I would like to show off my pride and joy, I do have problems with water ingress around the screen rubbers front and rear plus rear screen frame is broken. I am unable to fix at moment. A temporary cover over just the top half might be a short term solution for the next few months.
ScimiTom
Car Cover
Post by ScimiTom » Sat Jun 08, 2019 11:57 am
I can't recommend a particular type, but there may be something to be said for just leaving it uncovered to allow the body and chassis to 'breathe'. I discovered this the hard way when my previous Scimitar's paintwork started bubbling up within a matter of days after fitting a car cover.
Tom
Current: 'Boffin' (1971 SE5a)
Has thanked: 50 times
Been thanked: 259 times
Car Cover
Post by AJL Electronics » Sat Jun 08, 2019 12:15 pm
No cover is the best recommendation. A car port or the like if need be, but nothing that touches the bodywork itself.
Has thanked: 155 times
Been thanked: 1053 times
Car Cover
Post by scimjim » Sat Jun 08, 2019 1:20 pm
Lots of wax 😀
Where are you located? I have storage available because our prices are so competitive, we have cars from Kent, Brighton, London, etc.
Been thanked: 385 times
Car Cover
Post by peter freeman » Sat Jun 08, 2019 1:56 pm
I have four Scims that are parked on the drive - the one time I tried a cover on one it suffered from micro blisters - let the air dry it
TrevorG
Has thanked: 30 times
Been thanked: 34 times
Car Cover
Post by TrevorG » Sat Jun 08, 2019 3:21 pm
I've put pictures on previously of my scimitar that was covered while I was in hospital. My short answer is don't! We had a very expensive breathable cover, but she still bubbled all over. As said previously, a good wax is the best prep. Waxoyl the chassis etc. if worried about the underside. Enlarge the photo below to see the effect!
