Auto box change.
Auto box change.
Post by Jimscim » Wed Feb 21, 2018 12:03 am
Hi , I am a Newby to the Scimitar scene. I am looking for my first Scimitar and have noticed a lot of advertised cars are automatic, is it possible to change these over to a manual box. ?
Has thanked: 109 times
Been thanked: 692 times
Auto box change.
Post by scimjim » Wed Feb 21, 2018 12:08 am
welcome :D
auto to manual and vice versa have been done on all models of GTE - simplest is to pick up a breaker with your choice of box, then you have everything you need. Otherwise it's generally pedal box, gearbox, flywheel, spigot bearing, clutch, a little wiring if it's the overdrive and sometimes a prop depending onmodel.
that's assuming you mean a standard Scimitar box. Type 9 is a bit more complicated, T5 is a great box but expensive, RX8 will undoubtedly be done by someone soon.
Rev Light
Auto box change.
Post by Rev Light » Wed Feb 21, 2018 7:00 am
It seems to me that for every person converting a Scimitar one way, there is another converting it the other way.
Many on here rate the Auto highly. Why not try one.? If you don't like it, look for a manual. And don't discount the manual without overdrive. It's less complicated. Nothing worse than having a non functional overdrive......I have been driving mine around for 2 years.
SE5a 'Fancier'
Has thanked: 32 times
Auto box change.
Post by willholderogri » Wed Feb 21, 2018 8:51 am
love the autos myself
1962 mini, bedford CA , KR200. morris 1000, mini pickup.several escorts,ford cortina X2 ,astra, SE5A x 2 ,ford focus.
Auto box change.
Post by metalmoth » Wed Feb 21, 2018 9:59 am
My auto drives lovely
1982 SE6b factory black aka The Beast
What could possibly go wrong?
Auto box change.
Post by Jimscim » Wed Feb 21, 2018 10:11 am
Hi , Thank you for your replies .. I have always had a bit of a downer on auto boxes , probably goes back to the old days when they were not as good as they are today . Looks like I will have to go and test drive an auto and see how I get on . Thanks again , Jim
Auto box change.
Post by efi_sprintgte » Wed Feb 21, 2018 12:34 pm
6/8 series suit autos in my opinion (depending on use)
5 series not so much (however I have no intention kicking off this debate again :w)
Been thanked: 197 times
Auto box change.
Post by AJL Electronics » Wed Feb 21, 2018 1:18 pm
I agree that the 6 series go well with the auto box. If you want it even nicer, look for one that has an A4LD properly done, or do one yourself. It makes a really nice power plant.
Order your Scimitar parts any hour of the day at (member's discounts).
Fancy a holiday in Gael, France?
