MGF EPAS and Ardunio
- manny
- RSSOC Member
- Has thanked: 33 times
- Been thanked: 15 times
Good day all
yesterday I for some reason bought a MGF EPAS system ( ECU et all)...now i have seen speed controllers advertised for the speed and RPM? inputs- and wondered if an Ardunio could be used to supply suitable frequencies ??
And if so ..it would be possible to base the frequency out on GPS speed?
How are folks controlling the assistance maps in current installations - or is if just on\off ?
ta
Manny
ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Ti Progress#
1600 Progress#
GTC Progress#
- scimmy_man
- RSSOC Member
- Has thanked: 5 times
- Been thanked: 32 times
Re: MGF EPAS and Ardunio
why not on for first and reverse? off for the rest.
- peter freeman
- RSSOC Member
- Has thanked: 9 times
- Been thanked: 325 times
- Contact:
I do it on a pot - which controls a 555 timer. One owner I have fitted the EPAS for uses it only for very slow speeds then he turns it off for normal running - the other three use about 2/3 of the control all the time. No good limiting it for 1st in my case as I don't use 1st gear. Our EPAS drawing here http://www.scimitarweb.co.uk/~nenoggins/Wiring.htm
- AJL Electronics
- RSSOC Member
- Has thanked: 42 times
- Been thanked: 212 times
- Contact:
Not sure what the EPAS requires, but yes, the Arduino would make life easier for you and be infinitely adjustable to get it the way you want it.
- scimjim
- RSSOC Member
- Has thanked: 116 times
- Been thanked: 853 times
The MGF EPAS needs two square wave signals, 1000 to 3000 Hz for the RPM and 100 to 250Hz for the roadspeed.
- philhoward
- RSSOC Member
- Has thanked: 43 times
- Been thanked: 539 times
- Contact:
Easy way of getting a speed output is to use an ABS sensor (anything - whatever's cheapest on eBay; I used one from a Corsa I think), get it to pick up on a propshaft bolt or even the yoke, and feed it into an Orange relay used on non-ABS Corsas and Zafiras (part number 09185826) which will give you a decent signal to take into the Ardunio. You can then take that signal, scale is as required and send it back to the EPAS.
- manny
- RSSOC Member
well the Ardunio has a built in Tone generator - could it be that simple!!
https://www.arduino.cc/en/Reference/Tone
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Ti Progress#
1600 Progress#
GTC Progress#
- philipmasonfrance
- RSSOC Member
- Has thanked: 26 times
- Been thanked: 1 time
- manny
- RSSOC Member
keh??
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Ti Progress#
1600 Progress#
GTC Progress#
- td99
- RSSOC Member
- Has thanked: 16 times
- Been thanked: 22 times
That sounds promising, have just got an MG unit, but still need to find connectors and UJ.manny wrote:well the Ardunio has a built in Tone generator - could it be that simple!!
Couldn't find the manual controller unit on ebay referred to by Peter... So a substitute solution would be nice.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
- peter freeman
- RSSOC Member
- Contact:
Here it is - does may makes of cars as they all have the same sort of speed input.
http://www.ebay.co.uk/itm/Corsa-B-C-Kit ... aVIEYqNCmg
- peter freeman
- RSSOC Member
- Contact:
- manny
- RSSOC Member
looks like the Ardunio will only allow one pin to generate a tone- so i would need to generate the different frequencies between two pins - with minimal oscillation between the two to avoid the EPAS turning off
Or a simple 1500Hz isolated circuit to feed the engine 'on' and Ardunio feeding the speed sensor ( better option?)
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Ti Progress#
1600 Progress#
GTC Progress#
- td99
- RSSOC Member
yes I saw that and that's precisely what I searched for too!!!peter freeman wrote:I put his name on the EPAS drawing I did - it is Monday though/
Maybe because I logged in via Ebay Ireland (gives me English and Euros)
