Arduino projects for auto electronics, mini ECU etc
- AJL Electronics
- RSSOC Member
- Has thanked: 42 times
- Been thanked: 213 times
- Contact:
Calibrating standard fuel gauges with non standard senders
Out of necessity, I am working on a converter to map the standard fuel gauge to a non standard sender. I am working with two at the moment, an LPG and a petrol. My system will display the contents of each tank when selected.
Circuit is dead simple. One Arduino Nano. Sender signal connected to A1 with a matching resistor to a 5V regulator (Nano cannot provide enough current), Output from D9 into a 2K resistor which feeds the base of a TIP120 Darlington pair. Fuel gauge is wired to the collector, other side fed from 10V stabiliser as normal. I haven't tested it with a switching regulator, but can't see why it shouldn't work.
Software:
LPG_PetrolGauge
Fuel gauge conversion
The circuit:
* Petrol tank sender connected to analog pin 1 and ground.
240R 1W resistor connected from A1 to +5V regulator.
Value varies from 20R full, to 240R empty
LPG tank sender conected to analogue pin 0 and ground.
100R 1W resistor connected from A0 to +5V regulator.
Value varies from 0R full, to 90R empty.
PWM D9 connected via 2K resistor to the base of a TIP120.
Emitter grounded, Collector to fuel gauge. Fuel gauge to 10V regulator.
created 18/08/15
By Classic Microcars
// These constants won't change. They're used to give names
// to the pins used:
const int analogInPin = A1; // Analogue input pin that the petrol sender is attached to
const int analogInPin0 = A0; // Analogue input pin that the LPG sender is attached to
const int analogOutPin = 9; // Analogue output pin that the fuel gauge is attached to
int sensorValue = 0; // value read from the sender
int outputValue = 0; // value output to the PWM (analog out)
void setup() {
// initialize serial communications at 9600 bps:
Serial.begin(9600);
void loop() {
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
outputValue = map(sensorValue, 76, 460, 150, 0); // Calibration to the actual sender
// change the analog out value:
analogWrite(analogOutPin, outputValue);
// print the results to the serial monitor:
Serial.print("sensor = " );
Serial.print(sensorValue);
Serial.print("\t output = ");
Serial.println(outputValue);
// wait 2 milliseconds before the next loop
// for the analog-to-digital converter to settle
// after the last reading:
delay(2);
Software:
LPG_PetrolGauge
The circuit:
created 18/08/15
void setup() {
Serial.begin(9600);
void loop() {
delay(2);
Last edited by AJL Electronics on Thu Apr 14, 2016 10:39 am, edited 1 time in total.
- philhoward
- RSSOC Member
- Has thanked: 43 times
- Been thanked: 539 times
- Contact:
Re: Calibrating standard fuel gauges with non standard sende
Does it work the same as this: https://www.spiyda.com/magento/index.ph ... d-mk2.html
- AJL Electronics
- RSSOC Member
- Contact:
It can do more than that and the cost is peanuts. Arduino Nano and components for under a fiver. Low fuel output will be added to the software as it progresses, but should be trivial. Then there is the versatility. It can be asked to do lots more, mine will handle the gearbox requirements too.
- AJL Electronics
- RSSOC Member
- Contact:
I have made a little progress. The protoype board is built and the program is coming along nicely.
Would a seperate category for computer projects be a good idea? It may help people find previous relevant threads.
- Attachments
- image.jpg (128.82 KiB) Viewed 2685 times
- AJL Electronics
- RSSOC Member
- Contact:
Well it all seems to be working. Final software in case anyone else finds it useful. I'm aware that is could be cleaned up a bit, but I may do that when I have less to do. The USB connection is in the boot, so I can connect to modify the software easily...
LPG_PetrolGauge 25/08/2015
The circuit:
created 18/08/15
const int analogInPin = A0; // Analogue input pin that the petrol sender is attached to
const int analogInPin1 = A1; // Analogue input pin that the LPG sender is attached to
const int alarmLedPin = 13; // Low fuel warning light output.
const int petrolEnablePin = 10; // Input from fuel pump (petrol)
int outputValue1 = 0; // value output
int val = 0; // Tank switch value
void setup() {
Serial.begin(9600);
pinMode(alarmLedPin, OUTPUT);
pinMode(petrolEnablePin, INPUT);
void loop() {
val = digitalRead(petrolEnablePin);
if (val == LOW) {
lpgSender();
else {
petrolSender();
void petrolSender(){
outputValue = map(sensorValue, 301, 512, 150, 10); // Calibration to the actual petrol sender
// Alarm threshold SensorValue of 450 to put the LED on
if (sensorValue > 450) {
digitalWrite(alarmLedPin, HIGH);
else
{digitalWrite(alarmLedPin, LOW);
delay(2);
void lpgSender(){
sensorValue = analogRead(analogInPin1);
outputValue = map(sensorValue, 0, 514, 150, 10); // Calibration to the actual LPG sender
// Alarm threshold SensorValue of 401 to put the LED on
if (sensorValue > 400) {
else
delay(2);
The circuit:
created 18/08/15
void setup() {
Serial.begin(9600);
void loop() {
if (val == LOW) {
lpgSender();
else {
petrolSender();
else
delay(2);
void lpgSender(){
else
delay(2);
Last edited by AJL Electronics on Wed Aug 26, 2015 11:54 am, edited 1 time in total.
- AJL Electronics
- RSSOC Member
- Contact:
- AJL Electronics
- RSSOC Member
- Contact:
Next Arduino project started. This is a mini ECU to mimic the functions of an EEC-IV which controls gearbox kickdown and TCC lockup. This project will also monitor gearbox temperature and do the LPG / Petrol functions like switching, calibrating one fuel gauge for two tanks and controlling fuel pump and gas solenoids. The procesor is the Arduino Nano, that tiny bit of blue board, with the USB cable hanging from it. Case is still being designed and mocked up.
- Attachments
- IMG_1664.JPG (84.14 KiB) Viewed 2466 times
- IMG_1663.JPG (142.63 KiB) Viewed 2466 times
- IMG_1662.JPG (112.46 KiB) Viewed 2466 times
- AJL Electronics
- RSSOC Member
- Contact:
- philhoward
- RSSOC Member
- Contact:
Re: Arduino projects for auto electronics, mini ECU etc
What's the current rating of the outputs as they stand on the Arduino?
- AJL Electronics
- RSSOC Member
- Contact:
philhoward wrote:What's the current rating of the outputs as they stand on the Arduino?
http://electronics.stackexchange.com/qu ... uinos-pins
This is a bit complex. Basically, there are a number of limiting factors:
The IO lines from the microcontroller (i.e. the analog and digital pins) have both an aggregate (e.g. total) current limit, and an per-pin limit:
However, depending on how you define the Arduino "Pins", this is not the entire story.
The 5V pin of the arduino is not connected through the microcontroller. As such, it can source significantly more power. When you are powering your arduino from USB, the USB interface limits your total power consumption to 500 mA. This is shared with the devices on the arduino board, so the available power will be somewhat less.
When you are using an external power supply, through the barrel power connector, you are limited by the local 5V regulator, which is rated for a maximum of 1 Amp. However, this it also thermally limited, meaning that as you draw power, the regulator will heat up. When it overheats, it will shut down temporarily.
The 3.3V regulated output is able to supply 150 mA max, which is the limit of the 3.3V regulator.
In Summary
The absolute maximum for any single IO pin is 40 mA (this is the maximum. You should never actually pull a full 40 mA from a pin. Basically, it's the threshold at which Atmel can no longer guarantee the chip won't be damaged. You should always ensure you're safely below this current limit.)
The total current from all the IO pins together is 200 mA max
The 5V output pin is good for ~400 mA on USB, ~900 mA when using an external power adapter
The 900 mA is for an adapter that provides ~7V. As the adapter voltage increases, the amount of heat the regulator has to deal with also increases, so the maximum current will drop as the voltage increases. This is called thermal limiting
The 3.3V output is capable of supplying 150 mA.
Note - Any power drawn from the 3.3V rail has to go through the 5V rail. Therefore, if you have a 100 mA device on the 3.3V output, you need to also count it against the 5V total current.
Note: This does not apply to the Arduino Due, and there are likely some differences for the Arduino Mega. It is likely generally true for any Arduino based off the ATmega328 microcontroller.
My note: There are some limitations with the Nano, to do with the on board regulator. However, it will be powered by a stepped down, regulated 5V supply from the car electrics, so no issue.
- philhoward
- RSSOC Member
- Contact:
In that case, pumping voltage into a 470 Ohm load (probably 2 seperate loads) isn't going to worry it. I think I need to do this at 12V though so would still need to buffer it. I'm assuming this is how you're going to be driving the autobox solenoids and gauges, for example?
- AJL Electronics
- RSSOC Member
- Contact:
Yes, rather than use TIP 120s again, I have ordered a 4 way relay board, with contacts rated at 10A at 30V. It was a fiver, so will integrate that. Outputs are active low, I assume because the original ECU uses NPN power transistors for switching. There are two signals for the kickdown.. After a 500mS delay, the pull coil energises and drops out 500mS later after the hold coil energises. I believe that the hold coil stays energised as long as it sees a kickdown input. I just might try to incorporate a throttle position sensor at the pedal if I get bored enough. That will give me more information to the processor that may be usedful with an A4LDE.
- manny
- RSSOC Member
- Has thanked: 33 times
- Been thanked: 15 times
cool.. i was looking at using mine to display volt\temp etc - all very simple hardware wise- but i am no programmer...Andy clearly is.. ( at the moment mine is just in its box!)
very clever stuff..!!!- i got as far as hooking up a LCD screen and getting some temp\volt inputs but then lost interest..
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Ti Progress#
1600 Progress#
GTC Progress#
- AJL Electronics
- RSSOC Member
- Contact:
The gauge still needs driving with a power transistor of course as the output is PWM. Not much use for a gauge with just empty or full indications!
- AJL Electronics
- RSSOC Member
- Contact:
Not too difficult Manny. The first thing to do is to provide a potential divider, so that the pin Voltage can't rise above 5V. A three to one will do and will map 15V to 5V. Then in the software, you monitor the value coming out via the serial monitor and do some simple maths to convert it into a Voltage.
Current modules are available very cheaply and they just give you a voltage output relative to current.
delay(2);
Once you have that working, you can then incorporate the LCD which is quite straightforward as the commands are similar to the serial monitor function. Break the project down into baby steps and then put them together to walk.
delay(2);
