longer wheel studs
LRBkd
longer wheel studs
Post by LRBkd » Wed May 27, 2015 6:34 pm
In my search for longer wheel studs to accommodate the addition of some spacers for new wheels it has become apparent that lots of people want them for scimitars, MG's, Jaguars etc but none, so far at least, seem to exist in the original 1/2 UNF format. Ideally something around 66mm (2 5/8 in old speak) I've found a company that does custom runs of studs, question is, is it worth getting a batch made up? would anyone else be interested? or do I just convert to metric?
also does anyone know the spline diameter on the originals? its probably on the forum somewhere but I'm no Colombo..
philynnbob
Has thanked: 59 times
Been thanked: 20 times
Re: longer wheel studs
Post by philynnbob » Wed May 27, 2015 7:42 pm
14.8 mm
If you do want to go down metric route then this thread may help-viewtopic.php?f=63&t=21106&hilit=+Wheel+stud
Nigel Clark
Has thanked: 17 times
Been thanked: 42 times
Post by Nigel Clark » Wed May 27, 2015 8:02 pm
Try Moss Europe, they do longer studs for the TR6.
I fitted them with spacers to my TR so the Revolution alloys would clear the ARB drop links on full lock.
Nigel
philynnbob
Post by philynnbob » Wed May 27, 2015 8:47 pm
Hi Think you find TR6 spline/ knurl is too small for Scimitar hub (13.2 mm)
cookie
Post by cookie » Mon Jun 01, 2015 10:41 pm
Hi
I would be interested in a set of longer 1/2" unf wheel studs, about 10mm - 12 mm longer (3/8" - 1/2").
Cookie
Has thanked: 113 times
Been thanked: 791 times
Post by scimjim » Mon Jun 01, 2015 11:05 pm
philynnbob wrote:14.8 mm
It won't have been metric originally?
Post by scimjim » Mon Jun 01, 2015 11:12 pm
Speedshack say that they're NLA but if you drill the hub to accept a 15.62mm spline they can get 3" studs in 1/2" UNF (at a price)?
piman
Post by piman » Tue Jun 02, 2015 6:50 am
Hello Jim,
I don't know the comparative cost of Metric versus Imperial studs but surely when you add the cost of a set of Metric nuts the Imperial route should be cheaper?
Alec
1968 Triumph 2.5 P.I., Jaguar X Type estate 2.5, 1962 Jaguar MK 2, very long term restoration. 1991 Hymer 564 motorhome
Poppy
Post by Poppy » Tue Jun 02, 2015 4:36 pm
Not so, unless somebody has N.O.S. Metric items are made by the million, Imperial are not, except perhaps A.F
Tony
philynnbob
Post by philynnbob » Tue Jun 02, 2015 5:13 pm
Hi Jim
I got the 14.8 mm from measuring one I had removed so guess original measurement would have been 0.58 inch?
Been thanked: 510 times
Post by philhoward » Tue Jun 02, 2015 5:42 pm
I suspect it might be 9/16" and the 14.8mm measure man is the outside of the splines but you measure by the size of the drilled hole (or vice versa)?
Post by scimjim » Tue Jun 02, 2015 6:12 pm
I noticed speedshack mixed their units too :-)
GeeBee R3
Post by GeeBee R3 » Tue Jun 02, 2015 11:12 pm
1/2 UNF studs should be dirt cheap across the pond. I imported some ARP ones once and it was fairly painless as the value was below the dreaded Duty/vat thresholds
1972 SE5A
My boundless enthusiasm is unfortunately not matched by either time or budget.
K&Ns at discounted prices.
Alloy radiators coming soon.
LRBkd
Post by LRBkd » Thu Jun 04, 2015 5:44 pm
finally got a quote back for having them made, unit cost of £21!!!!! (sprays beer all over table, falls off stool, laughs hysterically...) I think not, time to search through ARP's range!!
I just want my pretty new wheels on..
