SS1 Vented 223mm Discs
Ben Kenobe
Been thanked: 22 times
Re: SS1 Vented 223mm Discs
Post by Ben Kenobe » Sat Aug 15, 2015 5:10 pm
Pretty disappointing - told me he had none - or he would be short of two at least ...
Has thanked: 23 times
Been thanked: 85 times
Post by swoakes » Sat Aug 15, 2015 5:24 pm
20 pairs available.
Tempted myself as spares for Sabre
Ben Kenobe
Post by Ben Kenobe » Sat Aug 15, 2015 5:28 pm
Well I'd go for two sets for sure - a spare set and a replacement set for the Sabre.
Been thanked: 854 times
Post by scimjim » Sat Aug 15, 2015 5:32 pm
Ben Kenobe wrote:Pretty disappointing - told me he had none - or he would be short of two at least ...
He had them done last week as so many people asked. They're an off the shelf disc re-machined.
Ben Kenobe
Post by Ben Kenobe » Sat Aug 15, 2015 5:36 pm
If they do the job I don't mind if they come from Mars ... :wink:
His 'new' sales person was supposed to keep me informed - unless he's left already ..
Has thanked: 75 times
Been thanked: 118 times
Post by reliant-reviver » Sat Aug 15, 2015 6:25 pm
Look different to the last ones given they are double drilled. Assume this is a new batch, if the pad /bell clearance issue has been resolved, i shall have to put a set into stock for when the day comes that my current ones wear out.
lookmumnohands
Post by lookmumnohands » Tue Nov 03, 2015 4:11 pm
Yes please, one replacement pair please !
Been thanked: 326 times
Post by peter freeman » Tue Nov 03, 2015 8:26 pm
Having acquired Corky's SS1 ( one of them anyway ) I have come into this subject rather late. The SS1 has vented discs but our Sabre still has the originals so it make sense to have them both the same. Reading Crouchie's post about the spacers he bought from http://www.ebay.com/itm/131133016724 I have just sent them a mail to see if they can supply spacers 18mm thick - seems to be the answer to keeping the price down if they can. All I then need is the discs - quick question do the ventilated discs use the same pads - I have spares in stock.
Post by swoakes » Tue Nov 03, 2015 11:02 pm
Yes the ventilated discs use the same pads
lookmumnohands
Post by lookmumnohands » Tue Dec 01, 2015 2:21 pm
one pair please
Been thanked: 473 times
Post by Roger Pennington » Tue Dec 01, 2015 2:33 pm
lookmumnohands wrote:one pair please
If it's the discs that you're after, then I think you need to contact GW direct, rather than asking on this thread? :wink:
Don't forget that if changing from standard, non-vented discs, you'll need to space out your callipers too, as mentioned in Peter's post
Post by scimjim » Tue Dec 01, 2015 7:25 pm
And longer wheelnuts along with the wheel spacers you need to clear the wider calipers.
td99
Post by td99 » Tue Dec 01, 2015 8:06 pm
scimjim wrote:And longer wheelnuts along with the wheel spacers you need to clear the wider calipers.
Longer Studs surely?
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Post by scimjim » Tue Dec 01, 2015 8:18 pm
Obviously! (Long day :-))
Post by reliant-reviver » Wed Dec 02, 2015 7:29 am
Pssst. Cheaper from QRG atm!
