SS1 Vented 223mm Discs
scimmy ben
Re: SS1 Vented 223mm Discs
Post by scimmy ben » Wed Jul 09, 2014 1:43 pm
Would a 230mm disc fit in the caliper? i.e. is there 3.5mm between disc and caliper?
Has thanked: 25 times
Been thanked: 85 times
Post by swoakes » Wed Jul 09, 2014 3:49 pm
Based on this photo of my Sabre with GW discs no :( Very tight to caliper say 2.5mm max
Has thanked: 264 times
Been thanked: 228 times
Post by CNHSS1 » Wed Jul 09, 2014 4:04 pm
aren't OEM solid small sports discs 221mm as std whereas GW vents are 223mm?
Been thanked: 540 times
Post by philhoward » Wed Jul 09, 2014 4:47 pm
I had 226mm in my head for some reason?
scimmy_man
Been thanked: 32 times
Post by scimmy_man » Wed Jul 09, 2014 4:56 pm
no comment
colinf
Post by colinf » Wed Jul 09, 2014 5:07 pm
I may be interested as i was looking into upgrading but was told that "they had no intention of making any more and that the "boss" wanted £750 for the one remaining set". So i bought a pair of solids instead (not fitted yet) as i was told there won't be any more of them either.
N.B. They charged me over £100 inc. postage for them
Colin F
G607 SS1 1600
Old enough to know better
Young enough not to listen.
scimmy ben
Post by scimmy ben » Thu Jul 10, 2014 3:49 am
swoakes wrote:Based on this photo of my Sabre with GW discs no :( Very tight to caliper say 2.5mm max
Ah, thanks...
Would need an external tickle then
scimitar79
Post by scimitar79 » Thu Jul 10, 2014 6:07 am
1. reliant-reviver, Philip andrew
2. Colintink
3. Colintink
4. Barry Topley
5. Steve Oakes (swoakes)
6. Roger Pennington
7. Spongeh
8. Minibull
9. Peter Smith (PeterSM)
10. EamonSE6
11. Phil Howard
12. Dave Green (Greeny)
13. Christopher Wise (possibly two sets)
14. Ben Kenobe (2 sets price pending)
15. Ian Leese aka mateybass
16. Paul Myers aka pauluspaolo
17. Doug Black aka sabre1800Ti (possibly 2 sets )
18. Matthew Gable (jps72)
19. Richard Erdman (scimitar79)
All good in sunny Nelson ;-))
chats371
Post by chats371 » Wed Jul 16, 2014 10:16 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
20. Adam Harris aka Chats371
Own a 1986 SS1 1600 was going to be a 1800Ti after Full rebuild but now gonna stick a 1.8 Zetec 130bhp in!.
1999 Lotus Esprit GT3 which has now been sold :-(
ChristopherW
Post by ChristopherW » Wed Jul 16, 2014 2:41 pm
Sorry but my interest has now ceased.
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
13. Ben Kenobe (2 sets price pending)
14. Ian Leese aka mateybass
15. Paul Myers aka pauluspaolo
16. Doug Black aka sabre1800Ti (possibly 2 sets )
17. Matthew Gable (jps72)
18. Richard Erdman (scimitar79)
19. Adam Harris aka Chats371
Crouchie_b
Post by Crouchie_b » Wed Jul 16, 2014 7:42 pm
Just to give you a ball park, I've just bought a pair of MG TF vented discs off eBay at £20 each & had them machined to fit by a local engineering firm for £50 the pair. (OD reduced, inner bore enlarged and 4 mounting holes drilled)
That works out at £45 per disc.
Photos to follow once fitted.
Crouchie_b
Post by swoakes » Wed Jul 16, 2014 7:45 pm
Crouchie_b wrote:Just to give you a ball park, I've just bought a pair of MG TF vented discs off eBay at £20 each & had them machined to fit by a local engineering firm for £50 the pair. (OD reduced, inner bore enlarged and 4 mounting holes drilled)
what calipers are you proposing to use :?:
Crouchie_b
Post by Crouchie_b » Wed Jul 16, 2014 10:18 pm
swoakes wrote:what calipers are you proposing to use :?:
Standard calliper, split & spaced using this kit http://www.ebay.com/itm/131133016724
EDIT - please note that having tried this kit, got the old chap to machine up a set out of 18mm plate as these where not thick enough to space the calipers correctly.
Crouchie_b
Post by swoakes » Wed Jul 16, 2014 10:37 pm
Right so basically the GW setup
Crouchie_b
Post by Crouchie_b » Wed Jul 16, 2014 10:46 pm
swoakes wrote:Right so basically the GW setup
Yep but without the (cough) £700 price tag :lol:
Crouchie_b
