SS1 Vented 223mm Discs
Has thanked: 72 times
Been thanked: 117 times
Post by reliant-reviver » Tue Oct 23, 2012 8:44 pm
Right following on from my latest Slice article and the thread started in the SS section here, lets have a formal thread for those interested in the vented discs.
For those who do not recieve Slice, here's what you missed:
the one and only reliant-reviver, overlord of all things rusty, underpowered and wedge shaped wrote:Vented brake discs
Next on the small sports agenda then is vented 223mm brake discs.
It came to light earlier this year that both GW and QRG had run out of the discs employed in the upgrade kits they have been supplying for the past years, with the last batch made in 1999 and having finally run out. Now despite what some misinformed Ebay vendors would have you believe, there is no off the shelf compatible disc from another vehicle which will fit, vented or otherwise. The SS1 solid discs were specific to the car, and so were the vented type made for the aforementioned dealers. Based on the previous cost of having them made, it seemed that this was going to be a non starter due to the massive minimum batch quantity predicted. However, after discussions with the chaps at Graham Walkers Ltd. there is now the possibility it will go ahead. A mimimum quantity of 100 discs / 50 pairs is required, Graham wasn’t overly keen on investing what is a considerable amount of money in stock that may sit unsold for years. I am trying to assure him otherwise though. With a large number of cars already using this setup out there, and more people looking to upgrade, surely there is enough interest?
Discs don’t last forever, and if you use harder performance compound pads they start to wear out rather quickly , indeed I am getting concerned now about the future of the 2 sets I have.
For those not aware, these vented discs are of the same diameter as the standard solid ones. This requires the calipers to be either swapped for Metro Turbo items which are wider, or to rebuild the calipers, fitting one of the readily available spacer kits which convert the standard width caliper to accept the thicker vented disc.
The benefits of this setup are that there is no change in braking force, thus leaving the car’s brake balance as the factory intended and not requiring the rear cylinders to be changed for different sizes. They are of course more resistant to brake fade, and I find them more than adequate on my modified 1900CVH and 1800ti SS1s, having not failed to stop with them once!
It seems a lot of people unduly give the original setup a lot of bad press, when really it is due to poor maintenance. Old brake fluid, corroded or worn discs and cheap pads, will give a truly shocking braking performance. The problem with this is a lot of (usually new) owners immediately blame the design / specification of the standard brakes and venture off on the “I need a massive upgrade” route.
I will agree though that the original solid disc brakes can be overcome with relative ease if used in real anger. In my view the answer for most cases would simply be upgrading to the dealer supplied vented discs.
SO, whether you are looking to upgrade for the first time, or to change your worn vented discs. PLEASE get in touch, we need an expression of interest in this if Graham is going to front the cash for a new batch. The price is currently looking to be sub £50 per disc. Original Reliant solid ones are over £35 a side now, so there really isn’t much difference.
I should say that £50 ea. is really the top end price, they may very well come in at a fair bit less I hope.
Anyway, FIRM interest on a pair.
1. reliant-reviver, Philip andrew
2. Colintink
3. Colintink
4. Barry Topley
A parting pic... mmmmm vented 8)
Has thanked: 22 times
Been thanked: 83 times
Re: SS1 Vented 223mm Discs
Post by swoakes » Tue Oct 23, 2012 9:02 pm
2. Colintink
3. Colintink
4. Barry Topley
5. Steve Oakes (swoakes)
Been thanked: 460 times
Post by Roger Pennington » Tue Oct 23, 2012 9:54 pm
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
spongeh
Post by spongeh » Tue Oct 23, 2012 10:24 pm
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
1987 Reliant Scimitar SS1 1800Ti
http://spongehuk.wordpress.com/ - My blog on all my toys
minibull
Post by minibull » Wed Oct 24, 2012 12:48 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
PeterSM
Been thanked: 24 times
Post by PeterSM » Wed Oct 24, 2012 8:01 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
9. Peter Smith (PeterSM)
Peter Smith
SS1 Sprint Car, 1800Ti SS1 and a very special Sabre DET
EamonSE6
Post by EamonSE6 » Wed Oct 24, 2012 8:14 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
Regards, Eamon
___________________
RSSOC Member 5691
1985 Se6B
1986 SS1 1600
Been thanked: 534 times
Post by philhoward » Wed Oct 24, 2012 8:28 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
Post by greeny » Wed Oct 24, 2012 9:04 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
12. Dave Green (Greeny)
ChristopherW
Post by ChristopherW » Wed Oct 24, 2012 9:38 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
13. Christopher Wise (possibly two sets)
Ben Kenobe
Been thanked: 22 times
Post by Ben Kenobe » Wed Oct 24, 2012 9:35 pm
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
14. Ben Kenobe (2 sets price pending)
Mateybass
Post by Mateybass » Thu Oct 25, 2012 2:51 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
15. Ian Leese aka mateybass
1991 Reliant Scimitar SST 1400 number 39 - Skippy's Facebook Page
1999 Subaru Forester S-Turbo Auto (LT)
RSSOC member no. 6883
pauluspaolo
Post by pauluspaolo » Thu Oct 25, 2012 8:29 am
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
16. Paul Myers aka pauluspaolo
sabre1800ti
Post by sabre1800ti » Sat Oct 27, 2012 6:23 pm
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
17. Doug Black aka sabre1800Ti (possibly 2 sets )
Doug Black
Ex-Factory 1993 Scimitar Sabre 1800Ti Mk 1
jps72
Post by jps72 » Sat Oct 27, 2012 6:46 pm
2. Colintink
3. Colintink
4. Barry Topley
6. Roger Pennington
7. Spongeh
8. Minibull
10. EamonSE6
11. Phil Howard
18. Matthew Gable (jps72)
Matthew Gable
228
1800Ti
Previosly owned 1800Ti & Middlebridge (no. 40 if you're counting)
